wife has been looking at my finewoodworkng mags again.. she showed me an end table that’s attached to the wall….
It seems that I’ve seen something but can’t remember about attaching furniture pieces to walls that make them look like they are floating…
can anyone send me in the right direction?
Dennis
PS… my classes are in the middle of making their final class project.. the stickey end table that was in Aug 06.. have been please with the results… still a lot of work on my part but the excitement of the students especially during spring, testing season is contagious… this is just the beginnig…
No replies yet? I have some vague recollection of Rockler having a piece of hardware that'll do that. Also seems like a sliding dovetail would work.
Screws through the back into studs -- just like hanging wall cabinets in the kitchen. Or french cleats if you want to get tricky.
Look up "french cleat". Easiest, most effective way, IMO.
Mike Hennessy
Pittsburgh, PA
That's it. The "French cleat"... I knew it was a european name and not the "Dutchman".... thanksDennis
I've also seen this done by bolting a plate to the wall that fits into a recess at the back of the table, then screwing the table to the plate from below. Picture the table as a box with one open side. That open side faces the wall and is exactly the right size to fit around the plate."Light the lamp, not the rat! Light the lamp, not the rat!!"
Rizzo the Rat, A Muppet Christmas Carol
What is the limit on a "french cleat" ?
A lot would depend on the depth of the "floating" table top and the amount of weight it will need to support. Kind of like a cantilever IMO. The further out from the wall you go, either the box has to get deeper or the supporting anchor has to beef up.
I say all that because I made and hung work stations in a beauty salons like that. I used 3/4 all-thread through solid blocking in the wall, the built the tops with beefed up backs and more blocking near the front in channels on each side of the drawer. When mounted on the wall with a nut pulled down tight on the back and another tight onthe front of the interior blocking, they were rock solid.
I took the idea from the way some commercial lavatory's are mounted.
Dave
both are good options... night tables are the items right now.. small lamps, books and maybe dealing with my fore arm while I'm sleeping...also planning on building a floating shelf for a couple trophys for a teacher at school...Again, thanks for the imputs..Dennis
For a stronger mount, I'd cut a 45 degree cleat from the top of the wall block. Glue the cleat onto the underside of the top. After it dries, attach the shelf to the wall. Drive a long screw through the top, through the cleat, and into the wall block.Now the screws are not bearing the entire load, especially if someone leans on the shelf or puts too much weight on it.
"What is the limit on a "french cleat" ?"
Well, that would depend on the wall it's fastened to, what it's fastened with and the construction of the box being fastened. This is one way (and a good one) that kitchen cabs are hung. My guess is that a full cab is going to be a lot heavier than a bedside table. (Unless someone sits on the table, then all bets are off!) If well bolted to the studs, I'd bet that the box frame would fail before the cleat.
Mike HennessyPittsburgh, PA
Furniture attached to walls?
Should be simple. Spend $79 staying at the Hampton inn. They've got plenty of that stuff.
Support our Troops. Bring them home. Now. And pray that at least some of the buildings in the green zone have flat roofs, with a stairway.
Use a piece of 3/4-in-thick plywood as the back panel and then screw it to the wall. We hang very heavy, plate laden upper cabinets and some pretty big, bath vanities with granite tops this way.
Gary W
gwwoodworking.com
thank you to all for your great answers... I'm always amazed about how many ways we can attack a problem.. (or skin a cat...) ;0P....Again, thank you
