I am working on some built-in cabinets and part of the adjcent wall has a bump out about three feet high. We want to put a solid oak top on the bump out to match the rest of the built ins but I am not sure how to attach it and allow for seasonal wood movement. The “base” is solid drywall so I don’t have access to the underside to use more conventional solutions like screws in elongated holes or sliding dovetails. About the only thing I could think of was to use a keyhole bit, http://www.freud-tools.com/freudkeyholb.html to secure one edge and glue the other edge. Any other suggestions are appreciated.
Thanks, Chris
If you can anchor to the drywall top securely with const. adhesive or a toggle bolt, you can use sliding dovetail keyways on the drywall, female part under the oak.
Good luck.
Why not make the top from oak plywood, with solid wood edgebanding. Then you can just use finishing nails to secure the wood through the drywall into the framing. In fact you would probably get away with just nailing a solid wood top. The drywall will let the nails give to accommodate the movement, though 30" would be larger than I would really be comfortable with.
Thanks for the suggestions.
Jackplane - good idea, a sliding dovetail keyway would certainly work although alignment would be tricky.
SteveSchoene - I agree plywood with edging would be easier but made the tops out of oak I salvaged from a fireplace mantle that was original to the house. It is pretty, old wood and I like the idea of keeping it in the house.
The top is only 9 inches wide across the grain (30 inches off the floor, 24 in long and 1 in thick) so I probably could get away with just nailing it. I wanted to try to keep the back edge flush to the wall and force any movement to the overhanging lip where it would not be noticed.
