I wanted to take a moment to say that back beveling planer blades works like a dream in preventing tear out on tough to plane woods. Thanx to a reply I recieved in knots. I am currently working with zebrawood for use in a table i am building for one of my customers. I had to wait a week for my sharpener guy to figure out how to do it to my satisfaction, but after 3 tries we finally got it. The difference is like nite & day between regular sharp planer blades with no back bevel & the blades that have the back bevel. Check out “FWW on Woodworking Machines” from 1985 (still available). Thanx again. This is another example of why I consider this publication among the best I read. Have a great day.
what is the technique? what angle how wide etc..
I have some burled Oaked to plane and will gladly dedicate a set of blades to a back bevel. Will it work on jointer blades too?
I used to keep a 10 degree back bevel on my Belsaw planer. Just turn the knives over with the sharpening jig set at 10*.
A light cut. Doesn't take very much. You got a badly hacked set of knives? Been finding nails or grit with your planer knives. Resharpen them at 10* from the wrong side. Gets rid of the knicks real easy. LOL
BJGardening, cooking and woodworking in Southern Maryland
I have been doing the same thing for several years. I take all my planer knives and hone a slight back bevel with a diamond hone. A few passes at about 5-10 degrees , is enough to create a small ( nearly invisible) bevel. It is amazing how such a small change can improve the performance .
I also, do this same thing to the irons on my bench planes, where the effect is even more noticeable. Of course with the plane irons I hone them to a mirror finish with my standard sharpening routine.
Rob Millard
Oooo, Zebra wood, that is really nasty stuff.
Be sure to check out the article that i mentioned, it goes into graphic detail about the angles neccessary depending on how your machine is set up. the back bevel turns the knives into more off a "scraper". Like i said, the difference is dramatic. & yes, be sure to do your jointer blades too.
