Bad bearing on Jet 18″ bandsaw
One of the bearings on the lower wheel spindle started squeeking so I thought I would have all the bearings replaced. When I was removing the bolts holding the bearing base I failed to notice the adjusting bolts where turning while I was unscrewing the hex bolts. Ack! I’m not sure how to realign the wheels now. Any and all help will be immeasurably appreciated.
Guy..
Jet Technical Support... 7:30 AM - 5:30 PM Mon-Fri. CST
1-800-274-6846
Regards...
SARGE..
Thanks, Sarge,Called Jet this morning and they said to use a plumb bob to align the wheels, as the top wheel can be adjusted to match the bottom wheel once the bottom wheel is installed and aligned using the plumb.Sometime I sits and thinks and sometimes I just sits
