When I resaw some flat sawn 8/4 white Olk it warps so bad that the last inch or so when I am resawing just pops from the stress the boards are 6 to 10″ in width and 6 to 8′ long the original 8/4 is flat with maybe a little twist but not bad I am new to this resawing but what’s going on the olk is all kiln dried to 6% I hate to resaw any more I have cut two boards and they both did the same thing any help would be appreciated I am cutting the boards to 3/4″ I don’t need to make fire would out of this wood.
Look at the end grain and the answer may be there. If it's plain sawn, it'll react differently from quarter sawn. Quarter sawn is much less likely to warp badly.
If you understand how wood is dried and then steamed it makes sense. That is a very common problem. You are dealing with the tension and compression in the wood.
Sounds like it's case hardened. The kiln operator should be able to manage this problem in general, however, white oak is apparently one of the more difficult species, especially the thicknesses greater than 4/4. If you're interested, Hoadley's book Understanding Wood has a discussion on case hardening and its management in the kiln.
Maybe you should see if you can return the stock as defective. If the case hardening is really bad, not only is it useless for your purpose, but it may be dangerous to work on the table saw.
I suggest patience. Let the resawn pieces "rest" for a few days. See if they flatten themselves out before any drastic moves.
Jerry
If it's case hardened (which it sounds like it is) you *might* get a decent board by resawing equal thickness off both sides. You *might* (less likely) then be able to resaw that board with less warping. Not what you wanted to hear, I'm sure.
Pete
thanks everyone for your input I think I will try to return and see if I can get this 8/4 in quarter sawn instead I let a couple of the boards rest from last week and put them between a couple of the heavier 8/4 boards and they flattened quite a bit but still a noticeable warp in them ,live and learn I think everyone is right about it being case hardened how does one tell ahead of time? about this problem!
