Has anyone used the baking soda removal system, marketed by Ace? I have a bunch of furniture to clean up, and don’t want to deal with chemicals.
Johnny
Johnny
In what sense is baking soda not a chemical?
What is it? How is it used? Varnish is not that hard to remove, even with the so called "green" strippers.
Hi Gretchen-
You're effectively using baking soda in a sandblaster instead of sand, so maybe it's not as damaging as sand would be. I read about it in one of the woodworking magazines. The unit hooks up to a compressor. I'm just looking for a way to strip varnish that doesn't use sloppy paint strippers. I'm open to suggestions. I have alot of 70's era simple (but strong) maple furniture that I want to clean up and spray a new coat onto.
I think you'll find that any abrasive that is hard enough to remove cured finish will remove some wood also, especially early wood, resulting in a very uneven surface that will require lots of sanding. Your 70's furniture is most likely finished with lacquer and should be a lot easier to strip with "chemicals" than to abrasive blast.
Michael R
