Call me crazy, but I like the look of all the plys in baltic birch plywood. So much so that I’m considering making shaker-style flat panel doors (roughly 18″X30″) out of the material. Out of 3/4″ material, I was planning to make simple stub tenon joints for the rails and stiles and use 1/4″ material for the panels. The finish would be polyurethane. I’m I crazy? Anything wrong with my planning? Anything to look out for? Thanks!
Are the panels going to show the plys? If so, your going to rip a bunch of strips and laminate them side by side to show the plys? I think they might cup.
markwdavis,
no, the plys won't show on the flat panels- just the face sheet. The plys will only show at the perimeter of the doors
jim
I use a lot of baltic birch and mix birch (birch outside, pine inside) and if the sheets are flat on purchace they stay flat but finish in and outside in the same way.
Ruud Joling The Netherlands
Exactly what is the best way to finish birch? Birch is well known for it's blotchiness. How can I get away from this and end up with a beautiful finish on my furniture?
Any comments would be greatly appreciated. Thanks!
I use Min-Wax pre-stain conditioner on Baltic Birch plywood when I go to stain it. I really soak to plywood with conditioner and let it stand approx. 20 minutes and using a clean, lint free cloth, I wipe it clean. I do both sides the same way. Test a piece of scrap plywood before doing the final piece. Fyi, use a good oil based primer on both sides if you are going to paint it.
Dave in Pa.
Most birch I treat with two or three coats waterbased PU and in my opinion it looks good.
Ruud Joling
