I have a 14″ Grizzly band saw and I need to either locate or fashion a dupplicator. There is an aftermarket unit made for Delta 14″ but Grizzly is not listed as a compatible manufactor. Any suggestions or alternatives for repetitive pattern cutting on the band saw.
Thanks – Doug
My bandsaw book's not here right now, but I know I've seen plans for home-made duplicators in the books. They looked pretty simple. Maybe you could stop by a Barnes & Noble or other big bookstore and take a look.
Thanks for the reference. Any particular author?
Doug
Hi Doug, sorry I'm so late -- been working on taxes, grrrrr.
Duginske, Bird, De Cristoforo for examples.
I have a great book here by De Cristoforo that has darn near all the power tools in it, and there's an illustration. I'll try to scan it and post. Wish me luck -- the book's so thick, it's going to be a challenge to get the drawing flat!
OK, drawing is below, but also: if the pieces are thin pieces you could stack and cut bunches at a time, then if they need to be spiffed up to be perfect, use a router and pattern bit.
Edited 2/28/2003 2:01:28 AM ET by forestgirl
OK, here's De Cristoforo's version. It's the simplest of the one's I've seen. From Complete Book of Power Tools, which is a compilation of two of his other books.
Thank you all for your efforts and information.
Doug Fowler
I belive Iturra sells one as well - seem to remember it was around $25 - looks like it would work well.
Here is one that Lee Valley sells. It may work on your saw http://www.leevalley.com/wood/page.asp?page=30053&category=1%2C41036&SID=&ccurrency=1Scott C. Frankland
Was the Newfoundland Wood Worker now the Nova Scotia Wood Worker.
Thanks Scott. I contact them to see if the unit will work with my model. I spend 3 great years as a teenager in Newfoundland in the mid 50's. Hard but beautiful land.
Doug
Silly me, I should have thought of Iturra. Yes, the have one, pg. 78, $20. They cite models for Delta and Jet.
I'm gonna lose my title of Catalog Queen if I make another mistake like that, LOL!!
Iturra phone 1-888-722-7078.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
