I am on the verge of purchasing a new bandsaw. Saving my pennies to get the best I can afford, of course. The one thing I know it will come with is a learning curve. Here are my first three questions:
1.How do you properly tension the blade, i.e. when is enough enough? Does the tension need to be taken off each time I leave the saw?
2.I see a lot of aftermarket guide blocks/rollers. Are the ones that come with a saw crappy and in need of immediate replacement?
3. Could I have recommendations for a book on band saw use?
Jed,
Buy the Band Saw Handbook by Mark Duginske. He covers all the bases: theory, technique, trouble shooting, blades, guides....
Some saws come with excellent guides, some, like my Jet, come with rather poor guides. I use Cool Block and like them very well.
Fine Woodworking had an article about bandsaw guides about 2 years ago. (April 2001) I found the article helpful.
I agree about Mark Duksinke's book, very good source.
Jed,
Blade tension depends on the particular blade. Top quality bi-metal blades, such as the AS-S blades from Timber Wolf (http://www.suffolkmachinery.com), are run at low tension, while lesser quality HSS blades require higher tension. Tension gauges are available, but FWW had an article with a homemade version about a year ago that would save you considerable bucks.
I have the cool blocks on el cheapo 14-inch Delta knock-off and they work great.
Bert
The whole idea about using bi-metal BS blades is to have the band made of softer metal so it can do the bend quickly without breaking and the hardened teeth for the cuttin'.
Once somebody figures out how to stick a fat carbide tip on a band & the band holds up till the blade dulls out.
It's bi-metal for me.
You can run a bi-metal blade much faster than a reg. one 'cause it can take the heat.
Check out Lennox blades at carbide.com or anywhere... Iturra has a nice selection.The proof is in the puddin'
I just read the Bandsaw Book by Lonnie Bird. I found it helpful.
Tris
Haven’t used a regular bandsaw blade for years. I have two Iturra carbide blades that do a much better job at every type of cut. Don’t be afraid of the cost because they out last and out preform all the rest.
When you say you want the best you can afford, how much is that?
Zombie, Gulf. Gotta figure in inflation now, too.
Personally I have discovered the Mafell jigsaw, which is no bandsaw but always works properly and doesn't take up half the shed. It can resaw a 5" thick piece of hardwood - but not at any great pace. Glacial, in fact. It does very well on all them curved cuts one must make here and there, though.
I like these zombie threads. Every now and then there's one with the "me" of 15 years ago in it. It's good to remind oneself of past daft-blather and faux-pas one has made. If we don't, we get all "I am never wrong"-ish. Everyone now knows how bad that can get! :-)
Damn, forgot to check the date....my bad.
I'd love to know how these things get resurrected. Fascinating.
full moon?
I think you should use simple google searches to find the answers rather than looking for a book. Books are pretty annoying when it comes to instant solutions to a problem.
Mostly the raising of the dead is by spammers adding a bad reply with a product link. The spam gets zapped away, but the thread is still up as having "recent activity".
“[Deleted]”
