I have 4, 7’6″ carved poles similar to the attachment to cut in half on a 14″ delta bandsaw. I’m concerned about the blade wandering on the bottom side where the cut can’t be seen. Is it helpful to score the the pole first with a circular saw to help with the tracking of the blade? Thanks.
sorry, the attachment didn’t take.
Edited 8/23/2002 9:44:17 AM ET by Don C.
I don't think so. I tried it once w/ some 10 x 10 oak timber and the blade went wherever it wanted to go anyway. It's all about tension and sharpness with a bandsaw.
Kinda hard, not knowing what the poles look like, but in addition to having a sharp and properly tensioned blade, perhaps you could build a sled of some sort that would help. I know in the last few months I saw an article, with pics, of an attachment used to make tapered posts for a canopy bed or some such thing, for use on a bandsaw.
FG,
Thanks for the advice and comments. I tried to post pictures but they just wouldn't take. They're about seven and a half feet long and vary in diameter from about 6 to 10 inches. The diameters vary with the carving. The best way I can describe these without pics is think totem pole. They're for a restaurant. They need to be cut in half and mounted to the inside corners of the walls symetrically around the interior. The outside corners are up, but the cut was 90 degrees to wrap the corners. I cut those with a chainsaw. I considered the Makita 16 1/2 inch circular saw for those, but $550 was a bit high for 8 cuts!
Thanks. Don
