I’m needing a 1/2 bandsaw blade and will likely go with TimberWolf. The intention is to cut 4″ thick table legs and tenons. The suffolk machinery guy on the phone said to go with 8RK (8 tpi), but I noticed on the website that blade is only recommended for much thinner wood (1 inch or so). He told me the RK would be slow going, but it would produce the best surface. I’m concerned though as the PC blade is more recommended for thicker cuts on the website. Could he have been mistaken?
Does anyone have any experience with the RK blade vs. the PC blade. And how many tpi would you recommend for cutting through 4″ thick pieces in order to get as smooth a finish as possible? The speed of cut is not important to me as I won’t be resawing, just squaring off the upper part of the leg.
Bankrupt
I bought from them and they are pretty good. He did not try to sell me the most expensive, but asked questions, and recommended a blade based on what I was going to do. I would take his advise.
I'm sure Suffolk gave you a good recommendation based on exactly what you asked for. It depends whether you really need the smoothest finish possible. I use a 4PC for everything except really big resaws(logs or more than about 10"). A new 4PC with no bent teeth (be careful unfolding it and installing it) will give a surface finish in most hardwoods that requires only light sanding or scraping.
Pete
Thanks. I went ahead and ordered the 4PC after calling back. I spoke with another rep and she recommended that blade. She did not recommend the RK blade (it's intended more for plywood and composites) and was concerned that 8 teeth would risk burning the wood, saying 6 tpi was as high as she would recommend for a smoother finish. I'm guessing the guy I spoke with yesterday has had good experience with the 8RK giving a finer finish on thicker woods, even though it is labeled for 3/4 to 1 1/2" hardwood. Given my inexperience with feed rates and knowing I'll eventually use the blade for multiple applications it seems the 4PC will suit me best.
Thanks to all for your input.
Did you order only one blade? Hmmmmmm, it's a good idea to have 3 or so at least. They bend. They dull. Shipping costs $$.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Yeah, I know. But take note of my handle. Norm just keeps forcing me to buy another power tool. No $ for accessories (kidding). Actually I already have a 1/4" Timberwolf blade for cutting curves. And with two small children (3 and 1) keeping me out of the garage, it will take me 2-5 years to wear out each blade. The buy 3 get one free deal is tempting, but it's money better spent on several more accessories I need for my next project...router bits, bullnose plane, etc. Golly, the hardward alone could run me over $100 if I go with quality reproduction hinges.
"to get as smooth a finish as possible? The speed of cut is not important to me as I won't be resawing, just squaring off the upper part of the leg. " This is why he recommended the blade he did. If you change your mind about how you want the blade to perform (finish v. speed) you'll get a different recommendation.
Edited 9/6/2006 9:41 pm by forestgirl
Sir,
I use a 6 t.p.i. alternate rake.
I use a 3/4 wide blade (3hp) and find the bandsaw doesn't work so hard as when usinging and 3 or 4 t.p.i. blade.
You can find a wholesale blade dealer in your town I'm sure who will order you any length you need for less money.
good cutting and watch your fingers.
Vance
Hmmm....I had considered 3/4 inch, but in the end I figured 1/2 would be sufficient for now and more versatile for other projects down the road. More of an all purpose blade, if you will. The timberwolf blade from the manufacturer is only $18.03 and about $5 for shipping, so I can't complain on the price. Thanks for the heads up, though.
