Hi All-
I’ve got an older 16″ bandsaw (a 1950’s Wallace) that I purchased a couple of months ago. In that time, I’ve broken 4 blades on the weld. In the absence of a manual for the saw, and not being an expert at tuning a bandsaw, I’m not sure if I’m over-tensioning the blade, or if the problems lies in the blades: I have them welded here in town at one of my suppliers’ place.
Any thoughts on what I should suspect? Tips on tuning a bandsaw blade when your saw doesn’t have a nifty little “Recommended Tension Chart” on the back?
Thanks in advance,
Chris, as far as tension goes FWW had an article on how to make a simple tension gauge a little while ago, I'll have to look up the issue # though. I think the problem you have is that after the blade was welded it wasn't annealed properly leaving a very brittle weld that would snap in no time. I would take the blades back to the person who welded them and have them rewelded or replaced. most companies that I've seen guarantee their welds. hope this helps
You might want to try a different blade -- If it were me, I'd call Suffolk Machinery (Phone:800-234-7297) home of Timberwolf blades, and have a long talk with them. They can give you all sorts of very good information, send you a blade, and be glad to answer questions later when you have them.
Another good resource for help on older bandsaws is Iturra design. They have a blade tension gage for $135 in their catalog.
Suffolk Machinery's website has a detailed page on how to adjust the tension on your blade, not quantitatively with a scale or something but by behavior/performance of the blade, which is ultimately what you need.
Its rule "A" on this page.
http://bandsaw.timberwolf-band-saw-blades.com/sixrules.html
Edited 5/12/2002 11:46:21 PM ET by LCHN
Chris, its the tires.. The blade is working in two directions at once. Thats not something bandsaw blades are supposed to do. Straight tension and you can usually crank them to whatever tension you like. In most cases, the blade will take far more tension than your saw is capable of producing. But.. if your tires are uneven or lumpy they will walk the blade in a horizontal manner and soon there after they will snap on you. In essence, the blade is oscillating.
Steve - in Northern California
Chris, I'd tend towards Andrew's thoughts on a brittle weld, but it that doesn't do it, some more detail might help. What blade size is this? Include tooth style, thickness, teeth-per-inch if you can. What are you trying to cut with this? Is it 3/4 inch, or 8-inches thick? Staight cuts or curves?
On tensioning, Suffolk's web site focuses on their low-tension blades, but can be a starting point. If you follow that and reduce the tension until the blade wanders (do it slowly), then tighten up several turns further than they say, and check with a test cut.
You only need enough tension to keep the blade on the wheel, and prevent any crown or bow at a moderate feed rate. What's moderate? If your cut's not vertical or you feel the wood jump as you feed, then slow down.
You might also try Lonnie Bird's bandsaw book to help in checking out the machine. Another fellow mentioned a tire problem. While it's possible, without knowing the blade size and what you're cutting I don't know how close that would be. A wobbling wheel or other issues can do the same, e.g. cutting 4" fast with a 1/8 blade.
If I had to make a guess, I'd take the simpliest one, and say you're over-tensioned and feeding too fast.
Gerry
Hi Gerry
Thanks for your response- to provide some missing information, I'm using a 1/4" blade (6 tpi) to cut 1" hardwoods. I try to be pretty conscious of not feeding too quickly, and don't feel like I'm shoving material in too fast, although I'll try slowing down more. I'm not cutting uncomfortably small radii, just long, soft curves that don't seem to put too much "twist" on the blade as I go.
I'll be putting a new blade on later today, and I'll take your advice on using a lower tension (using the Suffolk website as a starting point). Thanks again!Chris Gleason
Gleason Tableworks
http://www.interestingfurniture.com
Chris,
One other thought came in: flex the blade by hand to about 1/2 the normal radius, and move the weld to the edge. See if there's any visual difference there. Not sure how sensitive this test would be, but if you can actually see a difference, that's probably bad.
Gerry
I am not familiar with that machine center per se but you might wish to check to see if the wheels have any tilt. Sometimes tilt will be added to a saw so that blade strain is greater of the front edge than on the back. Sometimes tilt goes along with putting back in a blade (having the back side of the blade longer than the front side (so that the blade is a section of a cone rather than a section of a cylinder). If the machine center is set up to run with tilt and back, the wrong style blade will have unequal strain; if this strain is sufficiently dissimilar, you will break blades a lot.
Interesting! After recently changing the tires on my Craftsman bandsaw, I had my first blade break. Actually not my first, but it's been so long that I can't remember the last time. Over 10 years ago. There has got to be a connection to the recent changing of the tires. I did equalize the tension in the tires before running though??? The blade had been used quite a bit before changing the tires. I never reduce the tension after usage. The break was at the weld.
PlaneWood by Mike_in_Katy
PlaneWood
