Just changing blades to do some re-saw work when the upper blade hinge mount breaks!
I have an old “Transpower” 16″ bandsaw. Would anyone know where I can get parts? It is the same design as Grizzly and lot’s of the other early 90’s era Tiwanesse knockoffs.
Really need to get this back up quick!
Virtually all of the parts on the 14 inch Taiwanese bandsaws are interchangable between brands, I suspect that this is likely to be true also of the 16 inch saws.
John W.
Thanks John!
I ordered the part from another mfg and it works just fine!
I thought that these saws were all pretty much the same...now I know they are.
FYI- Transpower is a brand of CP Machine tools in El Monte, CA. I have bought from them and most machines appear to be the same as many others, but at a fair savings.
Thanks Craig,
Do you happen to know if they are still around...I couldn't find anything about them.
Lot's of these resaler of Import equipment seem to fall by the wayside....like Enlon.
Purchased from them less than a year ago, they were at AWFS. Also, they have a large parts inventory & know the tools they sell.
try http://www.cpmachinetools.com
Try Iturra Design
kalll@aol,com
1-888-722-7078
Work safely ¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬
