Hello All,
I’ve got a question for those of you more experienced with resawing boards on a bandsaw.
I’m just getting started on the rough milling of stock for a set of light weight knick-knack shelves that I intend to make with shelves only 3/8″ thick (to go with an old set of store bought shelves of the same thickness). I want to use some of the extra black walnut I have in my existing lumber supply but it’s 4/4 (1″) thick stock. Therefore, I thought this would be a good oppurtunity to try my hand at resawing for the first time (in order to conserve wood that would be lost/wasted if I planed the 1″ lumber all the way down to 3/8″).
The only problem I’ve run into is that when I resawed the first board (about 5-1/2″ wide and 24″ long) to take it down from 1″ thick to two boards approximately 1/2″ thick (allowing an extra 1/8″ for final jointing and planing down to the final 3/8″ thickness), the resawn boards immediately warped (a bit more than 1/8″ or so of lengthwise curve in the 24″ direction with no noticeable cupping across the 5-1/2″ width). Unfortunately, this is a bit excessive given the final thickness I need to achieve.
In hindsight, I assume this is the result of internal stresses being released in the walnut. Is there any way to avoid this much warping in future pieces? The original 1″ lumber has been in my shop for nearly a year, so I wouldn’t have thought that it has much, if anything, to do with acclimating to the humidity level (fairly dry) in the shop (although I stand to be corrected on that). Before resawing I cleaned up the surfaces of the 1″ thick board on my jointer and planer, and squared up the edges on the jointer to make resawing easier (or so I thought). Could this have had anything to do with the problem? Have I done something wrong? Should I have left the “cleaned up” 1″ board to stabilize/acclimate to the moisture content of the air in my shop before resawing even though the rough lumber had been in the shop for quite a long time (almost a year)?
As an experiment I did use my jointer and thickness planer to take one of the 1″ boards down to 1/2″ and did not experience any immediate warping. After one day this board is still straight. Can anyone explain for me why I experienced significant warping as a result of resawing on the bandsaw but not as a result of planing the board? Is it because when planing I took multiple passes alternating the sides being milled so only a little was being removed from each side with each pass?
I’d really appreciate any insights anyone can offer before I bite the bullet and use my planer to thickness these boards and turn 50% or more of my walnut into sawdust!
Thanks in advance!
Dru
P.S. Sorry for the long post. I just wanted to make sure my “dillemma” was as clear as possible.
I can't explain why the resawn board warped and the planed one didn't, but are they are two different boards? One may have had stresses from grain or case hardening while the other didn't.
Could be that the resawing generated a lot of heat and that caused the warpage. See if letting the resawn boards re-equilibrate for a couple of weeks helps.
Quite possible that you had a piece of reaction wood, and when you released the internal stresses, it popped on you. I resawed a 16/4 piece of maple earlier this year, and when I got to with 12" from the end of the board, the stresses were so high that the last 12" actually split on an angle. Sometimes, you just never know what you have until you work it. I wouldn't give up on the prospect. I resaw all the time, as I mill my own logs, and have lots of thicker stock. You'll be successful 95% of the time.
Like the others have said, you are releasing internal stress in the board. That is why it warped immediantly. I experience the exact same thing usikng a wood here that is knowen for being very stable. I rarely resaw 1 inch boards unless I am making them into veneers.
The only reason that I can see for why the other board did not move, is that as you joint and thickness the board you are suppose to try and take the same amount of material off of each side of the board. Thus the stress that the board is under are being released equally on each side. So the board remains stable. If you take all the material off one side of the board, then I think you would see the board really move.
Just my thoughts, good luck.
http://www.kalafinefurniture.blogspot.com
