I just received my brand new Powermatic PWBS-14CS with riser block. Problems started when instructed to check blade tracking(after installing riser block). Blade was of by 3/16 of an in. on the lower wheel. Triple checked tension and all, and was still off. Called Powermatic they told me to cut off the guide pins on the riser and plumb bob the alignment until he could send me another riser. Struggled with it for two more days then called back. The next person I spoke told me as long as the guides are adjusted correctly there is no problem. That just didn’t sound right after reading the bandsaw tune-up article. It took a while to put together, and I don’t fell like going through that again unless absolutely necessary. Any suggestions?
First I want to be sure I understand what the problem is. Is the blade centered on the upper wheel and 3/16" off center on the lower wheel? Also what size blade are you using and have you tried cutting with the saw?
John White
1/2 in blade. Yes it is centered on the upper wheel and off too the left of the lowere wheel. I did make some test cuts and the blade did not seem to drift. I am basically trying to figure out if this is something I need to be concerned with i.e. will thing wear prematurely or blades break etc. Thank you for your help.
It is more than likely that you can use the saw, as is, without any performance problems. 99 times out of 100 a poorly cutting band saw is suffering from either a dull blade or the wrong type of blade for the cut being attempted. So I would suggest that you keep a good assortment of fresh blades on hand and just go ahead and use the saw.
Track the blade more or less equally offset on the wheels, the blade a little to the right on the upper wheel and a little to the left on the lower wheel. Set the tracking with the guides completely pulled back so the blade can move freely with the tracking adjustments. Once the tracking is adjusted, set the thrust bearings and then the side bearings.
On this saw, if it is a typical Asian made machine, the bottom wheel can be adjusted to move it further to the left by installing shim washers behind the wheel. This is a fairly straight forward adjustment, Powermatic should be able to tell you if it possible on this model.
Maybe I don't have all the facts, but removing the pins from the riser block to correct the problem would normally be bad advice.
John White
John,
Thank you very much for your time and advice. That makes a lot of since to me.
Terry
