All –
I’m building a home bar (L shaped, approximately 6 ft x 8 ft). Would you think it acceptable to use 3/4 ” mahogany plywood as the bar top (with finished edges), or should I use solid wood (it will probably see moderate usage)?
Woody
All –
Woody
Strikes me as a little thin looking, would you consider a double thickness at least on the overhang like you do on a mantel and a taller edge molding to suit.
I would certainly opt for solid mahogany. Mahogany is stable and takes finish extremely well. You would have to allow for wood movement in the width direction, but the solid wood top could be expected to live as long as the house. The plywood would be much more suceptible to damage, both of the veneer and the laminates of softer wood in between the veneered outsides.
Probably longer than most of todays houses, I think the plywood would be fine with a good applied edge molding and a suitably hard finish. Solid mahogany could get pretty pricey for a bar of much size and intended for only moderate use.
Since the house is on fire let us warm ourselves. ~Italian Proverb
Thanks gents. Looks like I could go in either direction - solid mahogany (with increased $ cost), or 3/4 inch ply (with decreased longevity). If I go with the plywood approach, I will definitely make it appear thicker by using beefier edging (thanks for the tip).
I'm still sheetrocking and laying down the floor in the basement in preparation of the barroom, so I have some time to decide which way to go. Thanks, though, good too know either approach could work.
WS
Woody
Just some food for thought.......My favorite local watering hole is completely finished with mahogany woodworking, walls and all, including the bar. The bar top was fashioned with mahogany plywood, with a bar moulding edge. It is 14 years old now, and has held up pretty well, considering that the place is full almost every night, and sees a lot of action, including the occasional bar top dancer (not me!). I wouldn't hesitate to use the plywood, just use a durable finish.
