Batteries are like ink cartridges
Over the lifetime of an ink jet printer, a printer manufacturer will make far more profit from replacement ink cartridges than from the printer.
I notice the new HP printers have smaller cartridges and have made them much harder to refill.
I think that companies that make battery powered tools have came to the same realization.
PlaneWood
I sure hope Consumer Reports is listening to you.
Frozen lasagna family dinner: Serving size 1 cup, servings per container 5, finished off by 2 kids in minutes, I made a sandwich, wife got home late "Where's dinner?". I've been telling her to read labels.
Enjoy, Roy
Really! One of the battery packs for my drill died and they want $50 for a new one. I paid a little over $100 for the whole kit. Think I'll try to get by with one battery until the second pack dies, then replace the whole thing.
If you pay more for the drill the battery won't seem like so much :-)
Planewood,I've been converting old cordless drills to operate on 12volt dc via the car's cigarette lighter,using just a coilcord and and suitable fused plug.
Also for those requiring more than 12 volts, I use DC power supplys to convert them to corded. It's not rocket science, but they come in handy when working on a car or buffing up spokes and wheel covers.
Mixing paint etc etc.
Some of the smaller drills are rated at 3.5 - 7 to 9vDc. And they will go like the dickens and not heat up on 12-24-30 VDC Stein
Mike, have you (Or, anyone else) tried to refill HP cartriges?
I just picked up those 6 small bottles of re fill ink from a kit but no instructions (Cost 50 cents)
I assume you must ua]se a hypo dermic needle to in sert the ink ,but how much? Where's the fill hole ?
I would hate to take a loss, as every 50 cents count's nowa days. Ed. (Stein.)
Well, yeah, it requires a syringe and a small needle, then you gotta find the right hole :) !!!!!!! Putting yellow ink in the black hole don't work to good!
Stick the needle all the way in and slowly put in about 2 CC's of ink. The hole should be on the top somewhere. All cartridges I've ever filled had a sponge inside and what your doing is saturating the sponge. All instructions I've read say not to plug the hole when finished. If ink gurgles out of the top hole then use the syringe to suck a little out.
Wear latex gloves and work over a newspaper. It really can get messy.
To unstop a dried out cartridge use household ammonia mixed in hot water. Work it around the area where the ink jets are using a cotton q-tip. Or, maybe put a little of the mixture in a shallow saucer and let the jet area soak for 10 or 15 minutes.
It's best to refill them BEFORE they run out of ink.
Also, all kits I've ever bought have had instructions.
Also the ink has to be the right one for your printer. Ink formulations vary from one brand to the other. So if you are not using the right ink, the colors will be off. As for ink quantities, it depends of the cartrige. Usually the new cartrige will like the amont of ink in it. Varies from 2-3 ml to 12 ml for the big ones. If you are not sure, less is more ;) Do not overfill them and if you do remove some ink as it was suggested to you.
Thanx Mike and Forest Babe and Calendyr for your imput
re: ink jet cartridges.
I'm disgusted with the cost of ink cartridges and will try using your advice. Stein (Ed from Connecticut)
Eight or nine years ago, I used to buy the refill kits for the HP color and BW cartridges. It was such a hassle, and if anything went wrong, ink all over the inside of the printer. Yuck. Then Costco warehouse store started carrying the multipacks of the most-used cartridges. It's a big bite, buying a 3-pack, but their the high-capacity cartridges and one 3-pack lasts me a year (B&W). Or they also carry 2BW/1color I think.
Someday, I'm gonna make the shift to another printer mfg who provides separate ink cartridges for the components of the color. HP does, but only in the more expensive home printers.
I always buy Epson printers not only for their performance and reliability but the availability of cheap ink on Ebay. There is many people selling Epson printer ink so there is a lot of competition and low prices. I pay 2.75 for black ink and 3.00 for the color ink. These are not always Epson brand inks but work exactly the same. I get about 30- 8 by 10 photos from one setup. I have never went to the store and paid 30-40 dollars for ink, my Epson 785 printer only cost 50 dollars, why pay almost that much for one ink refill.
