Was wondering if anybody here has tried the “bead-lock” jig for doing loose mortise and tenon joints. Looks to easy.
Troy
Troy
Hi Troy,
It is easy and does work within its limitations. Size is one limitation, using their stock is another. If after giving them a good test run you decide this works for you, spend the money on the router bits and make your own stock.
Use a good electric drill, don't use a battery powered drill.
Take care, Mike
I used to use Beadlock a lot and agree the router bits are great over the long haul. I now use FMT or hollow chisel mortiser. Three things about beadlock. 1. use a small file on the indicator hole to make a bevel pointed to the wood. It is more accurate than the 1/16 inch thick metal hole there now. 2. use a strong fast drill to get trash out of the hole. 3. You really have to clamp the Beadlock jig to the wood cause it will move and ruin the joint. A heavy C-clamp with a block of wood on the back side to keep the clamp from maring the project wood.
cheers - lynford
Thanks for the info.Troy
I love the Beadlock jig. I don't own a mortiser and really have no place to put one if I did. The biggest fault i've found with the jig is the plastic knobs can be tough to tighten and may slip creating a sloppy mortise. I've seen replacemnet knobs for it at a woodworking show but i'm not sure if the guy made them himself or bought them. Buying the tenon stock can get expensive so if you use it a lot, I'd suggest buying the router bit and make your own.
