I guess the simple question is: Where could I get 1/4″ wood bead trim? Rockler’s/Woodworkers Store doesn’t have that size, and every place I was referred to in my area (and within 100 miles of it) didn’t have it either. I only need about 4″ to replace a missing piece on an old round table. Any help is appreciated! Adrianne
4" of 1/4" trim? You could make a scratch stock and make your own out of the wood of your choice. 4" is small enough you could just make it with a block plane or get real fancy and use a 1/4" bead plane or a Stanley #45 combination plane. If it's just a simple bead, I probably could have made it for you in about the same time it took to write this. Do you know any of your local wood workers?
Nope, don't know any woodworkers. To be clear on what I'm calling beading (because that's what I was told it is) it looks like a number of almost-oval-shaped wood beads cut in half (flat on the bottom, rounded on the top), connected together at their ends. What you're describing as beading sure doesn't sound like the same stuff. Since I haven't been here in a very long time and the format has completely changed, I don't know how to post a pic of it, but I can send a scan if it'll help. It's always the small stuff.............
Thanks for the reply, btw! Adrianne
Adrianne,
Lee Grindinger, who often posts here, had an article in Fine Woodworking about a year or so ago on making a similar molding. I'm no expert carver but these are relatively simple. Make a bead molding then use a gouge (maybe a #8 sweep or so) that matches the bead. Maybe someone else knows which issue. I'd hunt it down but I should have been out the door about five minutes ago.
Thanks for taking the time to reply, Larry. Unfortunately, you're dealing with less than a novice here - more of a do-it-yourselfer. My only concept of making this is to make an impression in a mold of clay or something and pour hot glue or some such thing in , then pop it out and trim to size. NO concept as to how to actually make this from wood, which would involve carving tools as far as I'm concerned.
The whole table will be painted once I get this section replaced. The table's round, 22" in diameter, and only this one section is missing.
Just to throw it out there, if anyone would care to make this for me, I'll pay whatever you'd charge. I've been looking everywhere for this stuff, or a way to make it myself, for about 3 weeks now - internet sites too - and can't find anything. You can certainly email me if interested.
Thanks for the replies!! Adrianne
Adrianne, take a clay impression of the good piece then make a Plaster of Paris casting of the impression. Use paints to imitate the woodgrain and your done. Plaster of Paris was used extensively in the 1800's for things like dental and acorn moldings. If nothing else, take the casting to a wood shop with a CNC router system and have them make a replica of the casting.
John
Edited 6/11/2002 4:37:46 PM ET by John
>> ... I'll pay whatever you'd charge.
Oh, goody! Now I can retire. :)
Back in the real world... If it's going to be painted, I agree that plaster may be your best bet.
Adrianne, if you want to post a scan, here's how: Make your scan and edit it so it's a reasonable file size (say, <30Kb). Save it to your computer, then go to Knots and click on Reply (to any of the notes in this thread). After you've typed your message, go toward the bottom of the Composition window and click on "Attach Files" and follow the instructions there.
I have a couple of restoration catalogs I can look in if you provide a scan for reference.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Well, I have a scan to post, but I don't seem to have the "attach files" option to get it in here. Only thing that appears at the bottom is post, preview, spell check and cancel. And below that, "here is the message you are replying to." I could be considered a guest, I don't know - could that be why I don't have that option? Doesn't make sense, but who knows?
I've attached scans a number of times in other forums, so I know how to do it. Now what? And thanks, forestgirl, for your help with this. Adrianne
Sounds to me like you are signing in as a guest. Just go create an account and you should be able to do attachments.. Well, I think thats the way it works. LOLJohn
Well, that's apparently not it either. I just read the registration wording and it says ifyou register as a guest, you can't post or reply to messages. So apparently I'm a registered member because I can do those things.
HEY! I just inadvertently scrolled to the bottom of this and there's the "attach files" option!! No clue why it didn't appear before. Stupid computers....... I'll try it now..........
Well, everything went ok until I pressed Done, then that window went away and this one was back, and when I started typing here the "attach files" window opened again. No clue what's going on, and I don't see any indication in this message box that my file got attached, even tho' it says it is.
How about if I send a volunteer the scan and they can post it here? I could be here all nite!
AAACK! I went to another site, came back, and there it was! Or rather THEY were, since I tried it twice and got no indication anything happened, until AFTER I posted, then left and came back. Really weird way to post pics here..........
So anyway, there's the beading. Hope the pic is big enough. Thanks to John and Uncle Dunc for the plaster suggestion. (I knew wording it the way I did about "paying whatever" was baiting, but couldn't figure out how else to word it at the time!!) Wouldn't plaster easily chip, as opposed to wood? And how would I attach it - with glue? It's so porous....
As for taking it to a wood shop - trying to find one, and then hoping they'd even DO it could be a feat. For such small stuff, I've found most people don't want to bother (take the time), which is why I offered to pay the billion dollars for this!!! :-)
Any other suggestions/help welcome!! Adrianne
Edited 6/12/2002 12:25:54 AM ET by ADRIANNE46
Adrianne, here's a quick but important tip: Any time you're replying or posting a new thread (or editing for that matter), it will take a few seconds or more for your post to show up. If you assume 30 seconds you should be safe. I think the stuff gets indexed in the data base before it shows up.
Now, I'll go back and look at your attachments!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
OK, you can get it from VanDyke's Restorer's catalog. Here's the page in there on-line catalog.
http://www.vandykes.com/product/02215104/
You can call them with questions -- they've helped me in the past and have been very courteous. PS: They have a couple sizes, but if they aren't the ones you need, there may be another restoration company that would have the right one.
Edited 6/12/2002 12:55:30 AM ET by forest_girl
Oh Forest_Girl, you are such a wealth of information. What a sweetie.. ;-)John
In a former life, I was probably a librarian, but being the forestgirl that I am now, I can't bear to stay inside in this life!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Hey, I'm kinda dense, what did that mean ?Steve - in Northern California
I was just poking fun at myself vis a vis my penchant for looking things up in catalogs and broadcasting information. A stretch, I know, sorry!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
LOL... I was just kidding.John
I couldn't put "everyone" in the To: window, so I'm replying here - to everyone!! who gave advice and help - thanks!!
Forestgirl, I appreciate the link and your research for me - will see what they have there - thanks so much!
And Joseph, I don't have a Lowe's, but a Home Depot, and that's the first place I went - nothing there. But thanks for the tip. Adrianne
Glad we could help Adrianne. For "everyone" click on the drop-down arrow in the "To:" box, and select All. Is there any chance that you clicked somewhere on "Basic View" and lost the advanced features? I think most people have found that not to work very well. Have no idea, though, if this affects the "To:" box.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
If there is a Lowe's home center near where you live, its worth a look. They carry, much to my surprise, a large variety of small molding profiles that are sold in short lengths. Just be sure to take your sample along with you and ask an employee- somtimes those things are hid pretty well.
"Hide not your talents, they were for use made. What's a sun-dial in the shade?"
- Benjamin Franklin
