My mother-in-law’s 60th birthday is coming up, and I’ve been “commissioned” by my wife (OK, perhaps “ordered” is a more correct word) to make a small presentation box for a diamond pendant gift coming from all the kids. Her mother grew up in Africa, and I’ve been asked if I can use woods from that continent to make the box. What would be some suitable beautiful wood species that I can obtain fairly readily? Won’t need big quantities, obviously.
Thanks!
-M.
MarkH
I don't know about availability, but some of my favorites are Mopane (brownish in colour, very hard, polishes beautifuly), Padauk (deep red in colour, hard, some small examples can be found on this page http://www.gtcreations.com/engagement.html ), Utile, African Mahogany, Sapele.
I don't know if this helps, but you at least have some names to thow around.
Ben.
Hello Mark,
Here's a page with various African woods and their working characteristics. I like Zebrawood for contrast in boxes - unfortunately I am allergic to it but I still use it sparingly.
http://www.woodworkerssource.net/Merchant3/merchant.mv?Screen=CTGY&Store_Code=WS&Category_Code=A
Be safe,
Ken
Mark, you've got some great choices among African timbers. Zebrawood has already been mentioned, but quartersawn sapele (a mahogany with fabulous ribbon striped figure) would be another. African blackwood (a rosewood often used as a substitute for ebony) would also be nice.
I don't know what your skill level is, but if you're up to doing any inlay work, pink ivory would be a terrific accent wood. This species has religious significance among the Zulus of South Africa. It is coral pink in color and so pretty it is used for some jewelry applications; beads, etc. It's scarce and expensive, but you wouldn't need much.
A couple of other good choices might be: bubinga or African padauk...if you have difficulty finding some of these rarer species...Or, if in your search, you come up with another choice, post what you've decided on. I'm sure somebody here on Knots will have had experience with whatever you find.
Hi Mark,
I would second African Blackwood and maybe do some detailing with some pink ivory. Both are highly prized African woods and are wonderful to work with. They are a bit pricy, but given how little you need migh not be too bad.
Cheers, Konrad
Thanks everybody!
Now -- off to try to find sources for some of these. I 'spose I'll start with woodfinder.com.
-M.
Here's another good site that lists a lot of woods and has pictures too. I found it this morning while trying to find info on so-called "Royal Mahogany."
http://www.wflooring.com/Technical_Info/Species_Tech_Info/indiv_specie_sheets.htm
Kevin
I think I would go with a box made entirely from ebony. Bubinga is pretty nice too, and you can even get figured bubinga.
http://www.forloversofwood.com/ <---good prices, and a pretty wide selection.
The only african wood I've worked with is zebrawood. It has a tendency to splinter and chip out easily. I had a lot of difficulty planing it, and never could do it successfully. But it sands really nicely and finishes up nicely. It has open pores, something like oak.
I've used some zebrawood veneer which had the cool property of chatoyancy, that is, the luster or sparkle changed as you tilted it in different directions, but the solid zebrawood I used did not do this.
