I’ve built several bedside tables using a Shaker design, single drawer, tapering legs. A friend of mine saw one of my tables and asked me to make him one. He said he would like to have a book shelf inserted between the legs about nine inches from floor level. I’ve never built this type of shelf and I need some guidance on how to notch the legs and add the shelf. I’ve looked for plans that have a similar design, but haven’t had any luck. Any tips or suggestions? Thanks.
Paul.
So sorry for the delay getting to your question. I hope I didn't slow down your project too much.
I've been thinking a bit about your question and my first suggestion would not be to notch for the shelf, but rather design stretchers into the lower legs that support a shelf.
You could design it with two stretchers, one on each side of the table, that support a shelf. Or you could install four stretchers that hold a shelf like a frame-and-panel. The first option is probably more suitable for a Shaker-style table.
Alternatively, you could notch the shelf and intall support blocks on the legs that hold the shelf where it meets the leg.
I've never really inspected a table that had notches cut into the legs so i'm not going to speculate on the best method for accomplishing that.
Matt Berger
Fine Woodworking
Matt,
Thanks for the tips. I like your idea about the stretchers. Before I try it, I may experiment with notching the legs on some scrap. Here's what I have in mind. I would make a jig that would hold a leg on a 45 degree angle with the inside edge up. Mount my stacked dado on the radial arm saw and set the depth of cut to about 3/4" into the inside edge
After I build the insert, I cut each corner on a 45 degree angle. The amount of corner removed would be the same as the depth of the notch in each leg. Then it's just a matter of gluing the insert into the notches when I assemble the table. I think that not notching the legs too deep would be the key to this approach.
Sometimes my brilliant ideas work better in my head than they do in application. If I get in over my head, I'll try your stretcher idea. Thanks for the help.
Paul
