Hi all,
I recently bought some rough sawn 8/4 beech. It looked great in the lumberyard, but within a week of bringing it home it has checked dramatically, with cracks running up and down the board. Some are 3ft long or more. I have heard beech can be a troublesome wood, but this seems exceptional. Is this what you’d expect from beech? Or is this a problem related to the kiln drying at the mill? Usually this place is pretty good, in my experience.
A bit more about the board. It is 6” wide, and although it is from close to the center of the tree, it doesn’t have the pith in it. Probably an few inches off center, based on the rings. The board didn’t have any wild figure, just some minor cathedrals.
I would expect the conditions at the mill and my shop are similar. The mill/yard has the boards stacked in bins inside of a enclosed, but largely unheated portion of the warehouse. My shop is is an unheated garage, but buffered a bit by the shared wall with the house. It mostly tracks humidity with outside.
I don’t own a moisture meter, so can’t check.
So, did I just get a bad board? Or is thick sawn beech to be avoided in the future?
Thanks for your input!
Hello! 8/4 European beech is one of my favorite woods to work with. I have made many projects with it and my situation is similar to yours in the way that my shop is Unheated and almost identical to the lumberyards conditions. I have never had any problems with major cracks or checks appearing when I have Brought it home. I will say since the grain has lots of rays like oak it can sometimes be hard to spot those checks at the lumberyard . I think you just got a bad board. Hope this helps happy wood working!!!
It sounds more like the board was green when you got it? I've never had any wood check that dramatically, including beech.
