Does anyone know the value of a Beis. 42″ fence ( only – no rails) ?
morty ,
Without the front rail and tubular section that has the tape measure on it , you could not easily make use of the fence the way I see it . I personally have mine set up only with the front rail , with no problem but the cam lock rides against the square tube so this is an integral component of the system . New ,I paid many years ago about $300 if memory serves me correct. I also bought a used one for $150.00 one time so for an incomplete system you may be able to purchase only the parts you need or spend much time creating your own .
best of luck dusty
