I am upgrading my bench and want to add square/rectangular dogs to it. What are the ‘standard’ dimensions for these? I have searched my back issues of FWW, Googled, and searched this forum, but have come up empty handed.
I am starting to conclude that there is in fact no ‘standard’ size, and people generally use whatever size seems good to them. I can do that too, but was wondering what people are using?
Dan
There's no standard enforced if you intend to make your own implements (dogs, hold-downs, etc.)
If you wish to use accessories you buy, though, obtain some of the ones you want and measure 'em. I have circular holes in my bench, in two sizes. The smaller holes (3/4") are sized for my bench dogs, and the larger (1 3/8") for my hold-downs.
I have no guidance on which to choose, just that if you decide to use commercial implements, you'll need to match 'em with your bench.
Have fun!
I am starting to conclude that there is in fact no 'standard' size, and people generally use whatever size seems good to them.
I for one just use 1 inch as in 'round' pegs with a square top glued to it so it don't fall through to the floor! I use 5 inches on center for what that is worth!
It really depends on the dogs you plan to use. Take a look at Highland hardware's web page for example. They offer two different sets of metal square dogs. The smaller ones are 1 x 5/8ths and the larger are like 1 x 3/4ers at the head. Other metal or prefabed dogs may have their own dimensions. If you are making your own from wood, you have the flexibility to make the holes the size you choose. If you plan to use premade ones, buy them first, and make the holes to suit them. Remember the 2-3 degree angle when chopping.
Remember the 2-3 degree angle when chopping. Geeee that's hard! Why I used round 'pegs'!
Even for round holes, you want a 2 or 3 degree angle towards the vise. This is so, when you apply pressure with the vise, it tends to scoot the dog deeper (and your workpiece tight to the bench), not lever it up and out.
My experience is that my round holed dogs stay put the face of the dog is slanted to hold the work piece down so that there is no movement. I'm satisfied with that.
Veritas !!!!!!. after forty years of wedging, nailing, clamping. I made a new bench and invested in the round dogs (these have sloping faces )from veritas and they are superb.if you want to hold odd shaped timber you just turn the face to line up with timber.I set my holes on 5" centres seems to be a good distance.Regards teabag.
Hey, nice name!
I'd suggest making your own bench dogs. Some small scrap hardwood, a small taper at the bottom and a hardwood spring... and you're all set.
