hi everyone…
im just getting into woodworking, and have been reading as much as i can here.
lately, i have been looking at a lot of pictures of workbenches, and i have a question regarding the placement of dog holes.
i apologize for not knowing who’s bench this is, but i found it in one of the threads here.
i understand the dog holes in blue can be used with the front vise..
i understand the dog holes in green can be used with the tail vise
but what about the dog holes in pink?
a newbie just looking for some enlightenment..
thanks
Two possibilities:
1) There's an end-vise as well as the tail vise, which we can't see in the pic. (Or one is/was planned to be attached).
2) More likely these are for a hold-down - a shaft with a curved spring piece sticking out at right-angles. You pound it down and the side friction locks the shaft in the dog hole...
IW
oak,
Dog holes are used for things other than use with a shoulder or tail vise: they're used as a stop when you're planing, for instance; they can be used with a hold-fast to clamp things--such as a bench hook or a shooting board--to the bench top when the neither vise will work; and, used in different locations on the bench top, they can hold oddly shaped stock. I'm sure someone else will explain other uses.
Alan
In addition to the other reponses, it occurred to me that having those holes there would be useful if I had to clamp an ellipse or round table top to the bench with the tail vise. You could get three points of contact which would be enough to plane it flat or carve into.
Kell
thanks for the input...
As the dogs look like Veritas ones, the holes may well be for their "Wonder Dogs"
http://www.leevalley.com/wood/page.asp?page=31129&category=1,41637,41645&ccurrency=3&SID=
Jason
