Hello ,
Sometime ago I bought a dewalt 12.5 inch bench planer.Recently I noticed that boards aren’t being planed evenly any thought on the matter?
Thank You
Hello ,
Thank You
I can try to solve your problem, but I will need some details about how the planing isn't even.
John W.
Thank you for responding. When I send a board through the planer the right side is planed more than the left.
Also when I try to raise or lower the height of the planer I have to use more force than I should.
Both the uneven thickness of the stock being planed and the difficulty in moving the head would indicate that the head has tilted which will cause the head to drag on the rods it slides up and down on.
The position of the head is controlled by a pair of screws, one on either side of the machine. The two screws are synchronized with each other so that they turn in tandem and keep the head parallel with the machine's table as the head moves up and down. For various reasons, the screws can get out of synch throwing off the machine's alignment.
On heavily used machines it is possible that the screws themselves, or the threaded sleeves in the head they run through, are worn out. It is also possible that parts of the chain or gear drive that connects the screws are worn to the point that the screws are slipping out of synchronization. If this is the case, you will have to replace the worn components before you can correct the alignment of the head.
If wear isn't the cause of the problem, it is also possible that one of the gears or sprockets in the linkage between the two screws has slipped on its shaft or that one of the gears or chains has skipped a tooth. This usually occurs when an attempt was made to move the head while it was locked, or already bearing down against some stock, or when the head was against a preset thickness control stop.
If parts aren't worn out, the following instructions explain how to bring the head back into alignment. I can't go into detail for your machine, but the process is about the same on almost any benchtop planer. With luck, the machine's manual will have a detailed description of the procedure specific to your machine.
To adjust the alignment of the head, you need to unhook the two drive screws from each other so that you can turn just one of the screws to move one side of the head up and down slightly to get the head again parallel to the table. Before unhooking the drive adjust the head so that it is about 3 inches above the table.
On most machines the two screws are hooked together by a chain drive, but occasionally a small geared shaft is used. On the majority of machines, the drive mechanism is under the base table. If you flip the machine over, you can get at the drive mechanism and unhook the chain or drive shaft, usually you have to remove a sheet metal cover to get at the parts.
On a few machines the connection between the two screws is on top of the machine, in which case you can get at the drive by removing the sheet metal or plastic cover that connects the two sides of the planer.
With the screw connecting drive unhooked, you can now turn the crank and move just one side of the head up and down slightly. Make a wood block with a screw sticking up out of it and adjust the screw so it just touches the smooth cylindrical part of the cutter head at the end that isn't being moved when you turn the crank. Now move the block to the other end of the head and move the head up and down with the crank until the screw again just touches the head. At this point the head will be parallel to the table, but go back and forth a few times with the block to be sure the setting is right.
Once you are sure of the setting, reconnect the drive, without moving the drive screws any more than the minimum necessary to reattach the chain, or mesh the gears, and you are back in business.
John White
Edited 12/29/2006 6:12 pm ET by JohnWW
