bench top planners and compact jointers
The current web page features a discussion of very small shops. I have to plan for a very small space. We plan to downsize our home as soon as possible my shop space will be very limited. At one time I had a Powermatic 8 inch long bed Jointer and a 15 inch Delta planner. They took up so much space that I reluctantly sold them. Is there a reliable bench top planer that I could bolt to a bench top and remove when not in use? The same goes for a jointer. I have seen shops in the UK and it is amazing what can be done in a small space.
You can do this with almost any of the portable planers, though the Dewalt 735 is pretty heavy. You might find this article useful, and the Makita is a good machine.
http://www.taunton.com/finewoodworking/subscription/Workshop/WorkshopArticle.aspx?id=30886
I have a SC fitted into a flip-top table that sits under the tablesaw when not in use.
I have a six-inch floor model jointer that isn't really big enough, but still manages to get in the way wherever I put it in my small shop. Had they been available back then, I would have gone for a combo machine. I don't think a benchtop jointer is worth having unless you confine yourself to making small pieces. At the moment I'm hand planing a 14" cherry board. I'd have to cut it into 3 to be able to use the jointer on it.
Jim
I think that you'll be hard pressed to find a good benchtop jointer. There are lots of good benchtop planers however. A combination jointer/planer will likely give you the best quality jointer, which as a bonus will likely be 10" or wider to match the planer. Inca made one, but I don't think they're around any more. I have one but haven't used it yet.
Thanks for your help.You have given me some great ideas.
I don't know anything about them but Jet just came out with 2 benchtop jointer/planer combos. One is 8" and the other is 10".
http://www.cpojettools.com/categories/woodworking/planers_and_jointers/planer_jointer_combination_machines.html
swifty - check craigslist for used INCA jointer/planer combo w/ tersa blades. For a small one-person shop, these are a great choice. I recently saw one in Fresno for @ $350. You get 10 1/4" jointing and planing
