I recently purchased a used Jet 14″ bandsaw. The machine itself is in great shape, but the blade needs to be replaced.
I’ve never bought bandsaw blades for wood and I’m seeking recommendations for the best value blades. In other words, like many of you, I’d be willing to pay more if the blade lasts longer or cuts better.
I don’t really ever do any resawing. That’s not to say that I won’t, but I just need a standard blade for now.
Thanks in advance for your help.
Curt
Basically for curves "any" carbon steel BS blade will work and they are cheap. I get mine from Highland WW for around $12 and keep a 1/4" 6 tpi on my small Jet BS. But.. for re-saw I use a 3/4" Lennox bi-metal on the 18" BS. Re-saw with standard carbon blades is not the best option as the carbon over-heats in that role and dis-tempers.
Many are going to tell you to get a Timber-wolf which is a low tension blade. I just personally don't care for low tension blades but most seem to love them.
Sarge..
Edited 1/13/2009 11:22 am ET by SARGEgrinder47
I love the Timberwolf blades and have had very good luck for all types of sawing from scroll work to resawing 12" hardwoods.
Second Napie's recommendation of Timberwolf Blades from Suffolk Machinery. They are a low-tension blade that's wonderful for our small saws. Your best bet since you're a first-time buyer, is to call them and talk to the staff about what kind(s) of cutting you plan to do, let them pick out 2 or 3 blades for you. If you're doing mostly curves, you need to match the width of the blade to the radii you're dealing with.
There's a "Buy 3, get one free" offer going on right now <click here>. It's a good way to go, get the most out of your shipping charges. Band saw blades don't last forever, even if you're not resawing.
Curt,
Read Michael Fortune's article about setting up a band saw and you will have a much better idea how to make decisions about blades for your saw.
http://www.taunton.com/finewoodworking/ToolGuide/ToolGuidePDF.aspx?id=24093
Rich
Michael Fortune gets his band saw blades from B.C. Saw in Toronto
Best Bandsaw Blades..
My opinion is Lennox blades Period! THEY know how to make blades!
