I make doors for kitchen cabinets. I use two router tables with TCT cutters. I’m considering buying a shaper. I note most shaper blades are HSS, and somewhat cheaper. Which are the most economical in the long run
John
John
Bits aside, if you make kitchen cab doors (a lot), you're better off with the shaper. The higher hp translates into faster production time and the larger motor and sturdier base means less vibration transmitted to your hands.
Most shaper bits are HSS only for molding, picture frames, etc. For doors, capinet or otherwise, there are lots of carbide cutters. Check out Grizzly, Woodtek, Woodworkers Supply, etc.
Agree with all above, believe the complete shop needs both a couple of routers and a shaper, with at least 3hp motor. This equips you to do a lot. For cabinet doors a shaper is the way to go, specially if you do a lot
Most good shaper cutters are carbide tipped. They are expensive though, a good cabinet set costing up to $300. If you really want to go custom, you can make your own HSS cutters, the set up to do this, being relatively easy.
Willie
