I’m building a desk with a leather blotter 18 inches by 48 inches. It’s glued to 1/4 inch mdf. A 1/8 inch sapele veneer is glued to the opposite side so that the blotter can be flipped over to use either surface. My problem: what to finish the sapele with. I’ve put 4 coats of de-waxed shellac on it, but want a couple of coats of clear finish over the shellac for additional protection (the client likes his scotch). I think an oil-based varnish will get a stale smell, and possible get gummy. The blotter lies on Baltic birch. Any suggestions are appreciated.
Water based poly.
I believe you won't have the smell problem you think with varnish. At least I haven't with Mohawk urethane varnish.
On the other hand, damn near everything will bond with shellac. Deft makes a nice water-based lacquer. Or, there's always water or oil-based poly.
You're only limited by yourself.
Hope I've helped.
Mikaol
I'd use water based poly.
As long as you give it time to cure I'd not be too worried. My favorite would be 3-mineral spirits 2- parts oil based poly and 1- part tung or linseed oil.
Water based poly without hesitation.
Thank you everyone. I went with water based poly (with hesitation). Looks good over the shellac.
