I am looking for the best woodworking lathe out there. I saw the helpful article on FWW, but I also heard that older ones are better and maybe I should by a used one. Any ideas on what the best quality one is?
depends
on what you want to do on it
ron
vintage lathes
want to be able to turn large table legs mostly. Do the vintage ones have more HP or are they unreliable?
options
Here's a review from May/June 2007 FWW:
https://www.finewoodworking.com/fwnpdf/011191074.pdf
Missing from the list, however, is Oneway.
http://www.oneway.ca/
What about vintage lathes? Ones that are like 50 to a 100 years old. Are these better than the newer ones as far as power and durability go?
oldies but goodies?
That depends entirely on the specific machine, the degree to which it was used or abused, and the level of care/maintenance it received during use. Restoring "old iron" often requires a fair amount of work, along with the associated special skills - things like welding cast iron, which some say can't be done, while others do it on a regular basis. Ever poured a Babbit bearing? ;-)
If you want to start turning fairly soon, I'd suggest you look at the current commercial offerings, appropriate for the type of work you want to do, from Delta, Jet, Grizzly, Powermatic, Oneway, etc.
