Hello Gang,
I have some A2 plane irons that need sharpening, and I have a few questions:
Since this steel takes more effort to sharpen than 01, is a diamond stone required, or will sandpaper do the trick?
I am trying to decide between a (monocrystalline) diamond stone (double sided 600/1200 grit) and the 15, 5, and .05 micron (1000,2500, and 9000 grit) sharpening paper from Lee Valley.
Could someone please explain the merits/pitfalls of each, or point me in the direction of a better product that I might not know about?
Thanks in advance,
Lee
Lee
If you are just honing a microbevel, then the extra effort is barely noticeable. Under these conditions the honing media is not significant.
I am presently experimenting with diamond paste (up to .5 microns), and this works great. But so do my King waterstones (up to 8000 grit/1 micron) followed by green rouge (.5 micron).
I am doing my a2 plane blades on the lee valley sandpaper unit. No problem that I can see.
Lee, I use DMT diamond stones followed by Shapton stones and find the results excellent
Lee,
I've been using A-2 blades in my planes for 8 years now, and I didn't see any difference between it and "regular" steel blades, as far as sharpening. I use a combination of oil stones and sandpaper (3M from Wal-Mart). After seeing an article in FWW a few years back about diamond paste on a hardwood block, I started using it, as a final polish, in place of leather impregnated with rouge; not because diamond paste cut any better, I just liked the idea of not having to worry about rounding over the cutting edges, which is a concern with a leather strop.
Rob Millard
All I've ever needed to re-hone my A2 blades is about a half dozen strokes on my stones.. where's the extra effort..?
Mike Wallace
Stay safe....Have fun
I use a 75 year old hard white Arkansas stone, works just fine.
