Hey everyone,
I am going to be building a built-in using Rift Sawn White Oak solid and veneer. My client wants a bleached look and I am looking for the best brand/technique to achieve the best look. I have read mixed opinions on bleaching White Oak, it sounds like a two part mix with a top coat is my best option? Has anyone tried a oil/wax finish with a pigment (Odies Oil or Osmo)?
I had a project a few years back where the goal was a white finish the you could see the wood grain through. I mixed water based poly with white latex paint, about 2:1 (poly 2) and the result was nice enough that I did not topcoat it.
_MJ_
I didn't know that was something one could do, thanks for the tip. I have to edit my question, what I am looking for is the best "bleaching" techniques. I have read mixed opinions on bleaching White Oak, do you have any knowledge on this?
If they do truly want bleached white oak, I have had good results with Zinsser's 2-part wood bleach. As you indicated in your post this would need a top coat; this is just a tinting process not a protective finish. The wood bleaching process is fairly simple. Michael Robbins' Try a Bleached Finish from FWW #263 (https://www.finewoodworking.com/2017/07/06/try-a-bleached-finish) can be helpful on process / technique.
I will just add that I had a client who wanted "bleached ash" finish. After many rejected samples, they sent photos of what they actually were after and it was best achieved by diluting latex paint to create a pickling stain. The pickling stain was rolled/brushed on and all excess wiped off. Repeated process as necessary for even coverage. Once this was dry/cured, I used a water-based topcoat (trade off in protection from oil-based was worth it to avoid yellowing over time) in a flat finish. The client was happy with the finish. This isn't better or worse than bleaching; in the end it was just the best way to get the look the client wanted. Photo attached.
Find out what your client sees as "bleached". More likely a look than a process they want. I have never used bleaching chemicals on wood. Oil will add warm tone and counter the efforts to whiten. I would advise all waterborn here.
Make up some test panels and give them a decision to make so they can't dislike "your" choice later.
These are my favorite finishing products, see if your client is looking for the whitewash color on this link shown on oak, could be an easy solution.
https://generalfinishes.com/all-colors
If this thread is still active...or if we're just sheltering in place...or whatever; I just got a request for a solid bleached white oak kitchen table top.
Kind of going on the assumption that the designer was either blowing smoke or following the white oak bandwagon, I decided that while I was making the white oak sample board, I'd make one out of red oak as well. On each board there were 4 sections: my controlled variable (clear coat), then 3 sections of 2 part bleach. One of those sections got a whitewash after the bleach, one of them got a 2nd bleaching, and the 3rd got Liming Wax after the clearcoat. I ripped a keef down the middle of the board, making 8 sections, and did a water based clear on one side, and oil on the other, to show the distinct difference between them.
This is a long, shelter-in-place induced way of saying that although white oak was specified, red oak with a bleach coat and whitewash with an oil topcoat won the day.
So never stop believing or something.
