I posted this on BT, maybe a couple of you may like to see it too.
I found this on another mailing list, last working steam sawmill in the country, capable of cutting long sticks (80ft). |
WOW. That was cool.
Thanks for shareing.
Pardon my spelling,
Very Cool
Really enjoyed that!
sharpblade,
Thank you very much!
I really enjoyed it, it took a long time to download, (over a half an hour (dial up) ) but certainly it was worth the wait..
saw mills facinate me and a steam sawmill this size is something to really appreciate!
My saw mill can only nibble at the sides of logs that diameter, much over 4 feet generates a lot of waste!
It is also limited to 19 feet at max. There is a sawmill in southern Minnesota capable of sawing a 46 inch wide board and if he cheats the carriage he can get around 22 feet, but 80 feet? six foot diameter?
Makes you in awe of logs that were hundreds of feet long and maybe ten feet or more in diameter of the old growth forests doesn't it?
Most interesting video, anyone know what those "things" are on the opposite side of the blade from the teeth? Could they be part of the drive mechanism for the blade? KDM
"... Buy the best and only cry once.........
Interesting question, I wondered about that too but my guess is that's another set of teeth, and in this particular case they are worn out.
I don't think they are needed to drive the blade. Bandsaw blades are driven by friction between the wheel and the blade. True for a tiny benchtop, and in the case of this monster even truer. The surface area between wheel and blade is large and the tension enormous.
Another reason, if these teeth were for driving they would need to be in the opposite direction. You can pull the blade into the cut, buy hooking a sproket in the gulley of the tooth, but you can't push it. Draw a picture of the blade around 2 wheels and think about it.
Again, just a SWAG, anyone who can think of another one please say so.
Glad you guys enjoyed this. I did too and I don't usualy get impressed too easily :-)
As I mentioned, we're having a paralell discussion on BT. Here's a link to the restauration of the ship mentioned on the sawmill page.
http://www.nps.gov/archive/safr/local/thayrest.html
Other thread at http://forums.taunton.com/tp-breaktime/messages?msg=83104.8
in which poster "junkhound" who visited a similar mill confirmed the teeth-on-both-sides theory.
S.B. I think you are correct about the blade. See Terry Lee's post a few down from your's. KDM"... Buy the best and only cry once.........
Looks to me that the blade is double edged, the other side is wore down and need sharpening.
Duke,
If it is like the commercial bandmill down the road from my farm, the blade cuts in both directions. A friend of mine knows the sawyer and we visited the mill. The carriage goes back and forth cutting in both directions.
Thank you for the interesting post. I really enjoyed it.
Has to re-sharpen the BS blade every 2 hours - WOW!
thanks for sharing, an enjoyable read.
Thanks for posting that link.
David Ring
I live about 10 miles from that mill. Besides having that big bandmill they run the whole place with steam.
I think that was a great post. Capturing history of our hobby is pretty cool. Thanks for the effort.
