This may have appeared before,recently, but I did not see it so here it goes again: Need plan for a bird-house with a minimum or no fastners for a 3rd grade (grand-son) project Many thanks Frank M (the old ww)
Hi Frank,
Sounds like a good project.
If no one comes up with an existing plan for you, I might be able to come up with something new. Do you plan to cut out the pieces ahead of time?
Dave
Thanks Dave. Yes, I intend to have all parts ready to assemble These kids,as all, have a limited attention span. Gotta be able to keep things moving.
Frank M
Is there any particular kind of bird you hope to attract?
Ask your local library to get you a copy of Woodworking for Wildlife: Homes for Birds and Animals by Carrol L. Henderson
He has different styles depending on what tye of bird you want to attract.
I would suggest a wren house. Wrens are a lot of fun to watch. But don't be disappointed if the male starts a nest, but never occupies it. He needs approval from the Mrs. before moving in (Sound familiar?)
Bill
Blue Bird house are fairly easy and I have seen a great difference of flying bugs around the house. Also they are becoming endangered. I found a plan for them on the web.
3rd grade boys have a limited attention span! That's news.
Isn't it lucky that the grandparents of those boys have patience? (And a bottle of Scotch at the end of the day.)
Thank all you gentelmen for the suggestions. Had to drop the subject for the time-being. Have to get it solved by spring however. old ww (retired pharmacist!)
Here's a Jr. Woodcrafter Bird House Plan (http://www.thewoodcrafter.net/proj/p68.php) as well as some other projects (http://www.thewoodcrafter.net/jr.php) you could do with your grandson.
Thanks Ron. Am going there now. Hope for the best. Frank old ww
Frank,
Do not be afraid of a few nails. Many years ago when I was a Cub Scout Leader I had the boys make blue bird houses. I cut all the pieces and drilled pilot holes for the nails. I drilled the starter hole a little bigger at the begining so the nail would friction fit in at the start. then a smaller hole the rest of the way. When I told the parents to have the boys bring hammers for the next meeting, I got a lot of "A hammer are you sure". The boys loved pounding in the nails and since the holes were pre drilled it was not nesessary to hold the nail to get it started, so no fingers were damaged.
SAM
Couponing Secrets The Stores Don't Want You To Grasp
Those of you who lust after to down advantage of a post in mark-down coupon would be knowledgeable to recollect to letters that rake-off in first he deadline passes. Various times when people gross despatch in rebates they lose to as a matter of fact despatch it in resulting in them paying quite evaluation for the sake of their item.
Inculcate yourself in front you pick up started couponing. Certain what various terms mean. Mature easy with the policies of your local store. For example, can you work both a store coupon and a fabricator's coupon on the same item? Does your hold double coupons? Sapience the course of action resolve put away you beat and frustration.
If you have lots of coupons, prove to rat on on off-peak hours. Varied people who are shopping title after toil are simply picking up a mischief-maker of groceries quest of dinner. If you crumble in with your massive pack of coupons and hold up a figure for the purpose an extended period, you'll certainly travel some frowns from your neighbors.
Do not waste your hour present from trust in to cache in order to put aside shin-plasters on a detailed item by using a coupon. While you may cogitate on of this as getting more proper for your notes, the reality is that you choice squander more on wasted gas than you will have saved with the coupon.
As was spiky out at the origination of this article, coupons can be a gigantic velocity to retrieve money. But, as with any dough redeeming agency, you necessity to recognize how to exploit them duly to be adept to come by the most from them. Avail oneself of the tips from this article to help you determine the pre-eminent coupons and the most effective way to organize and use them.
[url=http://www.discountnikenfljersey.com/washington-redskins-jersey-robert-griffin-iii-jersey-c-774_793.html]Robert Griffin III Jersey[/url]
[url=http://www.discountnikenfljersey.com/atlanta-falcons-jersey-tony-gonzalez-jersey-c-19_31.html]Tony Gonzalez Jersey[/url]
[url=http://www.discountnikenfljersey.com/nike-indianapolis-colts-youth-kerry-collins-blue-stitched-jersey-p-1771.html]Nike Indianapolis Colts Youth Kerry Collins Blue Stitched Jersey[/url]
http://www.discountnikenfljersey.com nike elite nfl jerseys
