Hi all
just curious
what is the best type of bit to use to make mortises using a drill press??
I’ve mainly used Forstner bits but wondering what the pros use
thanks
Pabs
Hi all
just curious
thanks
Pabs
Production shops use this type of carbide bit:
http://www.dimarcanada.com/products/product_details.php?familyIDVar=7&pLineIDVar=2&categoryIDVar=88&groupIDVar=294
David Ring
If the mortise is small enough, a brad point works much faster, I find. For through mortises, you can tilt the work to clean up the side walls. But for larger mortises, a forstner.
thanks for the feedback
Pabs
