Has anyone used or seen any reviews for the Black and Decker table Saw? I saw one in a store and it looked and felt good but am not sure of it.
Rick, if you are a weekend warrior and don't intend to use if for much more than a few simple projects then the B&D might just be what you need. B&D is the homeowner line for the company. Dewalt is their industrial line. Look at the difference between the two and you'll see what I'm talking about.
Here's the corporate website http://www.bdk.com You can learn a lot about a companys products by reading their SEC filings and their annual reports. If there is any profit loss do to problems with a product line, you'll usually find it in the SEC filings.
Steve - in Northern California
Steve - Good point about the SEC filings - B&D Corp. - parent of many brand names is not having a good year. They are having losses in many divisions and right now they are laying off hundreds of folks at its Easton, MD plant (where many DeWalt items are made). They are in the process of moving many tool items to China and other off shore manufacturing sites. Just as they did with DeWalt about 15 years ago, I suspect they will do the same with B&D - that is, downgrade DeWalt to homeowner status (it's headed that way already) and revive the old B&D commercial products like worm drive saws, Macho hammers, Sawcats and the industry standard, the Holegun. Nolan Archibald, the CEO will be retiring in the next 10 years so he has good reason to pump-up sales of one of his major divisions.
They certainly make for interesting reading don't they. That's how I verified that Delta was having big problems with quality control and customer service. The SEC filings show that the parent company knows about it and has promised the share holders that it was fixing the problem. It definitely swung me away from a 14" Delta bandsaw and into a Jet 18". Steve - in Northern California
You struck a nerve here when you mentioned Delta...I am now the proud owner of a DeWalt 12 1/2 inch planner which replaced a Delta that didn't last a year. The Delta had so many things going for it when I bought it. Price, ease of use, great dust collection hookup, light weight. But then I started on a big job and it quit right at the start of it. This happened just about the time Delta and Porter Cable were merging. I went to the local Delta service center and was told it would be several months wait to get it repaired. The problem was a common problem I was told. The screw that holds the belt pulley to the cutter shaft worked loose. This allowed the pulley to start to walk. Next the keyway went and as a result the belt melted the guard and then self-destructed. I decided I'd repair it myself since I didn't have a lot of time to wait. Still had to wait a month for the parts. When received I found that (although the screw that holds the cutter shaft works itself out because it's not tight enough) I couldn't get the screws out of the covers to make the repairs. They tork those suckers in like they're assembling a 747. I already had a B&D Chop Saw. It's the work horse of my small shop and has given about 5 years of no trouble service. So when I decided to bite to bullet and give up on the Delta planner I had no trouble laying out the extra bucks for the DeWalt. I hope you guys are wrong about B&D's future. I'd sure hate to lose that company.
Wow Bill, thats some story. I probably shouldn't have brought up the "D" subject. I don't want to accidently hijack this thread. I hope B&D works things out too. They have always been a company I felt I could trust and I have some great, older B&D tools. I'm not a fan of the new stuff just yet but who knows. Steve - in Northern California
Steve, I feel the same way about Delta, believe it or not. I didn't mention that I also have a 10 inch Delta Table Saw, 6 inch Jointer, Table-top Band Saw and also a Drill Press. All of which have given several years of great service. But if I never see another Delta Planner it may be too soon. Good to talk at cha.
Bill,
wow is that funny, I have plenty of reason to hate Delta, I bought a Delta 12 1/2 inch bench top planer that came without handles and it took over a month to get that fixed. Once I did, it's worked like a champ for me. I bet that suckers planed well over 5000 bd. ft. of white oak. without a hic-up.
But wow, do I hate their contractors saw!
Rick, two questions
f_g - I found the instructions for table saw alignment and posted them in the ripping oak thread. Thanks ...
Here are the specs and pictures of the saw... Looks lik its a 15 amp induction motor that has a developed HP rating of 3hp. I would bet it's direct drive. At 145lbs its about half the weight of our Jets. Definitely the saw falls into the homeowner class. Looks pretty nice.
View ImageView ImageView Image
10" Table Saw
Self-aligning aluminum fence slides smoothly and locks parallel to blade
Fence Micro-Adjust for quick and accurate fence fine tuning measurements
Powerful 15A, 3 Hp motor
Large cast iron table provides stable, smooth work surface
Oversized shut-off switch is easily activated with either hand or knee
Extruded aluminum legs with oversized rubber feet for rigidity and stability
T-Slot miter gauge stays in slot when using with extended material
Dust extraction port attaches to shop vac or dust bag for a cleaner work environment
See-through blade guard with anti-kickback fingers for visibility and safety
Easy assembly: takes less than 1/2 the time of other table saws
Separate locking height and bevel adjustment wheels are easy and intuitive to operate
Dust Port Diameter 2 1/2 "
Max Width Of Dado 13/16 "
Amps 15 Amps
Shipping Weight 154 lbs
No Load Speed 4800 rpm
Table Size (with extensions) 40 1/2 x 23 1/2 "
Blade Diameter 10 "
Arbor Size 5/8 "
Depth Of Cut At 90 Degrees 3 3/8 "
Depth Of Cut At 45 Degrees 2 1/4 "
Max Rip To Right Of Blade 25 "
Max Rip To Left Of Blade 15 "
Tool Weight 145 lbs
Edited 4/22/2002 12:46:51 AM ET by Steve Schefer
Edited 4/22/2002 1:08:03 AM ET by Steve Schefer
Edited 4/22/2002 10:39:42 AM ET by Steve Schefer
Hi Steve, thanks for finding that! Hopefully, he won't need to give his saw the "full treatment" but I found it very comforting to have your instructions in my archives.
I'd be surprised (make that flabbergasted) if this B&D saw is belt-driven. It'd be interesting to know the price, 'cause I'd bet it's close to $400 or maybe even more. I just can't see paying that much for a direct drive saw.
How do they get 3HP with only 15A?? Hmmmmmmm.
Howz your lumber-storage project going? (ooops, here I go hijacking again!) I'm working on a drop-down/pull-up router table that attaches to the Jet (left wing). Putting the legs on tomorrow!
Lumber storage... Oh yeah, that's another thing I was supposed to do this weekend. Well, hey, I did the laundry, cut the lawns, washed the truck, cleaned the shop, almost finished the marble table, Salvaged two 8' x 24" by 6/4 pieces of clear heart redwood from an old barn, took the rabbit out bar hopping, bbq'd for a half dozen friends, planted the seeds for the garden, re-potted a few plants, made a set of wheel barrow handles for my dad and fixed a computer for a friend. Jeeze, now that I think of it there is a reason I'm as tired as I am.
I really need to get that lumber storage system built. Maybe I'll start it tomorrow evening after work. I can't work on the table until the BLO dries.
As for 3hp at 15amps... Induction motors are rated in amps and the HP is the theoretical developed hp not the load hp. It probably compares to about a 1 hp regular motor. Steve - in Northern California
Steve, do you ever sleep?!? An amazing list of accomplishments! I think the last time I was able to maintain that kind of activity level, I was still a write-off on my mom's income tax! Wow!
"...rabbit out bar-hopping" !! Not sure how to translate that one. :-) forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I told you about my rabbit didn't I. Well, I took it out bar hopping Saturday night. Really, I did... It was too funny, what a chic magnet. LOL.Steve - in Northern California
FG:How do they get 3HP with only 15A?? Hmmmmmmm.
Short answer: They don't. That figure is so-called "developed horsepower" that is reached just the instant before the windings melt (Bosch advertises 4.4HP for their 15A benchtop 4000, which has got to be a joke). Someone may correct me, but I think developed horsepower is more commonly given with universal motors, because it looks so much more impressive than the corresponding figure for induction motors, another reason that it looks to me awfully like the B&D has a universal motor. --That's not necessarily a criticism, depending on what you're using it for, only you should know before buying
I've been sitting at the computer for too long -- thought you wrote "...before the wingdings melt" ! :-)
Yep, suspect you're very right about the "developed HP." I've read about that, and universal vs. induction motors, but the stuff sticks in my brain about like cooking oil sticks to Teflon. Oh, well.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Hey, but if nothing sticks to teflon how do they make it stick to the pan?
Edited 4/22/2002 12:03:30 PM ET by Steve Schefer
Rick and All
I saw the B&D table saw in a recent magazine (Family Handyman or Wood??) and then again at Lowe's. Price at Lowe's was $399. It looks pretty cool. I am pretty sure the magazine said it was a universal motor (LOUD). I plan on getting a new table saw in a year or so, so I'll be interested in actual experience.
Stan
