I just acquired an old gallery clock that I am rebuilding. It dates from the 1920s. The finish is almost opaque black and shiney. At first I thought it was painted. The wood grain almost does not show through the finish. Then I took a laquer thinner wipe to the back side and the color and shine rubs off easily leaving darkly stained wood. So I suspect that this is a laquer finish. And being so dark I also suspect that it is black laquer. I need advice on how to repair and refurbish this finish. I need to fill some narrow voids in the joints and hide the filler with new finish. Where should I begin?
You already washed out the finish, so you don't need to think about the previous finish.
What you need to do is rewash your finish until it clean enough, until no more paint can be removed with your thinner. It mean that no lacquer or sealer left on the wood. If there is some color on it it is okay.
Let it dry for a few minute, and scuff sand your wood.
Yes you can putt filler or putty if you need to do it. Use the filler or putty that has similar color with your finis.
After that you can apply finish you want.
Good luck
wisno
Good luck
wisno
Jet black aniline dye in an alcohol solution (see Behlen's at woodcraft) works well, is easyto use to blend in repair work. Then cover with any finish you like.
Jerry
First off, Jerry, I want to thank you for your comments. While waiting for Knots' response I discovered Behlen's laquer products and I have already ordered them for this project.
Now as to Wisno: I did not wash out my finish. Did you read my post or are you making things up as you go? I did a spot test on the back to determine what I was dealing with and the results came up laquer. I have no intention of removing the finish entirely because that would leave me with badly stained wood with far from a natural color. I needed instructions on how to work with a dark black laquer finish and how such a finish from the 1920s differs from a modern one. You failed on all counts. I think it would be better if you did not respond to posts here as you are apparently not very wis. Thanks
Wow, great way to make friends.... As long as we are pointing out faults how about your spelling?
Doug -
Ease up - Wisno tried to give you some advice -
Thanks to all here that lend opinions -
Lets keep everyone here and not hurt feelings -
The site is a place for information opinions - no one knows it all - me for sure.
SA
