Being in a northern climate, I have yet to live in a house that didn’t have some black stains on the wooden window frames due to condensation during the winter. It isn’t mildew, it’s actual rotting of the very surface layer of the frames, next to the glass. Is there anyone who has successfully been able to remove these stains before refinishing the wooden frames? We have over 50 Anderson windows, most of them crank out style, and they are otherwise in fine condition. I did a small test using a few drops of undiluted bleach, and it seems to work somewhat, but before I go hog wild, I was wondering if anyone has any other ideas to test first. Also, if I do use bleach, do I need to do something to neutralize it before top coating it with several coats of a wipe-on polyurethane? Thanks.
I have successfully used Oxalic Acid to remove a few black water stains from oak but I've never used it on such a large scale as you require. Still, it might be something to consider.
What type of wood? The best thing I've found for removing water marks and stains on wood is Murpheys oil soap in warm water and using a white terry towel rag rub like hell!
Oxalic acid is the best wood bleach I've used.
John, have you ever had success removing black condensation stains with oxalic acid? I haven't had much success thus far with either bleach or oxalic acid, but if you have, perhaps you can shed some light on how you did it.
Oxiclean( hydrogen bleach) will take care of the mildew, thats mostly what that black is -scrub with a tooth brush and it will remove a lot of the black staining as well. Then try the afore mentioned Murpheys Oil Soap, hot water and a terrycloth rag. That will do a lot to remove tannin bleed. Chlorine bleach is pretty destructive to wood and you need to neutralize it. I've used oxalic acid to lighten wood, it's a long process and kind of nasty stuff and I haven't found it to be that effective at removing stains. Excellent brush cleaner though. I made all my windows, they're redwood and single pane glass. I get a fair bit of condensation so I get water sitting on the bottom of the sash. The water rolls down the glass and gets between the glass and the sash or mullion and then underneath the finish. You try to seal that but the glass and the wood move at different rates and any sealing you do gets compromised. Cleaning and touching up is an annual event.
