just over hauled a walker turner 14″( late 40’s early 50’s) dosen’t have a tension guage for the blade would like to buy one if posible. is there any way of telling how tight to have the blade i am doing the old pluck the blade sounds pretty tight not much deflection thanks dan
the folks at old woodworking machinery group on yahoo would be able to help you out on that.
or try http://www.owwm.com
Chills
will post there also thanks
Get some scrap wood.. Tension as light as possible to track the blade..
Test a cut.. Tighten.. So on... Best cut you get.. Then mark the screw wit white-out or somethin!
Tension is to keep the blade from slipping on your tires. ie big blade...big tension
then what controls the bending of the blade at the cut line.
Edited 6/13/2005 11:06 pm ET by BROWNBAGG
I think it's all them blade guides...???
Actually, if the tension is great enough not to slip then the blade won't flex at the workpiece. I have a friend that built a bandsaw from wood in order to use a 2" blade. He doesn't have any tires on this and his tension is adjusted to keep the blade from slipping on his wooden wheels.
Joe
Old post but I use a 1 inch 3 tooth LENOX blade for re-saw..
I moved the blade side guides away from the blade and set the back of the blade bearings to 'book called for'..
I get nice cuts.. Well, cept for the un-even feed for ME!
