Does anyone know where I can get blades for this great saw? Neither Bosch nor Skil have any left in stock. The blade identifier is 27593, has a 3 inch toothed section with 2 holes at the top. One hole locates onto a pin and the other accepts a threaded screw. I have one blade left!!! Thanks.
By the discription you give, it sounds like a pretty typical jigsaw blade. If its the same as the bocsh blades its probably available at the hardware store.
I'm in the kitchen industry and we use a lot of jigsaw blades. The bayonet type for quick release blades and the screw fix type like you describe. A generic brand generally makes them and will save you money rather than buying the "brand" name ones
