So for 60 bucks at auction I bought some antique tool dealer’s collection of rejects… either lesser planes, a minor chip here and there, stubby irons or missing parts. At the top are a crude Stanley #110 on the left and Sargent’s idea of a low-angle block on the right…an adjustable mouth, but too large for my hand and too little support for the iron. At the bottom from left to right are two, more desirable Stanley #60 1/2 low-angle blocks, a Stanley #65 also with a low-angle, 12-degree bed, and a standard-angle Stanley # 9 ½ with a 20-degree bed, all with adjustable mouths. I’ll rehab them all and sell or give away what I don’t need. I order the parts required from Stanley…eccentric levers ($2.00), a replacement iron ($6.00) and miscellaneous screws from their catalog:
http://www.stanleytools.com/?TYPE=ST…rtsservice.htm
I dismantle them and toss them into a phosphoric acid solution overnight. The acid attacks the rust without touching iron or steel, and leaves behind a protective coating of iron phosphate in pits and recesses, inhibiting further rust. I much prefer this rust removal method to any other for tools used in damp boat sheds.
A day later all rust has been converted to sticky crud that has to be cleaned off.
I begin with a coarse wire wheel, followed by a bath in hot soapy water with a small wire brush to clean the recesses, a good rinse, and drying over mild heat:
I take these back to the buffer grinder to clean off the after-rust developing on the flat surfaces where I scrubbed off all the iron phosphate using a fine wire wheel….
…with special cleaning attention with a Dremel Tool given to the critical bed and mouth areas.
I buff the exterior surfaces to a shine using green rouge.
Continued…..
“When we build, let us think that we build forever. Let it not be for present delight nor for present use alone. Let it be such work as our descendants will thank us for; and let us think…that a time is to come when those (heirlooms) will be held sacred because our hands have touched them, and that men will say, as they look upon the labor and wrought substance of them, ‘See! This our father did for us.’ “ –John Ruskin.
And degrease with mineral spirits followed by strong trichloroethylene, a suspected carcinogen, so here I wear gloves, which are also necessary to keep my oily fingerprints out of the blued finish.
I then cold blue the parts using phosphate blue (Brownells.com). This solution hides rust staining, inhibits further rust, but most importantly is an index dye for the critical stages of flattening irons and soles.
Before sharpening I check my stones for flat using 60-grit wet-or-dry paper on a precision-ground, cast-iron surface like this jointer table. A couple strokes done dry allows sighting down the stone to find any hollows still shining amid the stone dust made by the abrasive paper. If I have to flatten the stone I use kerosene as a lube and rub the stone till until I have a perfectly flat surface. I’ll never get a good edge without perfectly-flat iron backs, and I’ll never achieve flat backs without flat stones.
As you can see by the indexing blue remaining after initial honing of the backs, all of these irons will require more work on the coarse stone to make the blue near the cutting edge disappear. If the iron back isn’t dead flat at the cutting edge, the high spots (relative to the sole) with blue remaining won’t get as sharp and won’t attack the wood uniformly with the remainder of the edge…the plane drags in use, and the cuts aren’t smooth.
Common after flattening these old irons is to wind up with high spots at the corners of the cutting edge that simply won’t go away.
I could simply grind the iron back a few millimeters, but this iron doesn’t have much life left so I simply hone a slight back bevel or 2 degrees or less into iron’s back until the blue at the corners disappears.
This blued iron is adequately flat far enough back to accommodate a number of quick resharpenings without having to mount another major attack on the back.
Once more to the jointer table with 60-grit lubed with WD-40, I attack the plane soles. First I mount the iron and set the adjustable mouth to the position in which it will be used the most often, and then remove the iron to flatten the entire sole assembly. You can see how badly this Sargent’s sole is out of flat by the index dye remaining. This one is pretty bad, and will take two sheets of 60-grit followed by a sheet of 100-grit to make true. I flip plane ends around every few strokes to make sure I’m flattening the sole as evenly as possible.
Continued….
“When we build, let us think that we build forever. Let it not be for present delight nor for present use alone. Let it be such work as our descendants will thank us for; and let us think...that a time is to come when those (heirlooms) will be held sacred because our hands have touched them, and that men will say, as they look upon the labor and wrought substance of them, ‘See! This our father did for us.’ “ --John Ruskin.
View ImageFew are as bad as that Sargent, but when they are that bad, keep in mind that soles don’t have to be absolutely perfect like iron backs do. Just the toe, both sides of the mouth and heel need to be in the same plane to do fine work. In fact, Japanese planes are purposely set up with hollows in between my ink marks to reduce friction. Much of the chattering woodworkers complain about in Stanleys isn’t because the iron is dull or too thin, but because the critical area behind the mouth is in a hollow and is unsupported by the work piece....just like an entire third of the Sargent's mouth is in a hollow. Indexing dye makes a huge difference in how well you flatten, and flat is what makes the plane work well...or fail to. If you aren’t using it, you may not be flattening as well as you think you are.View ImageI’ll do some trial work using three fettled planes. From the left, a stock #60 ½ I just finished above, my old standby #65, and a near-new Lie Nielsen #60 ½ low-angle rabbeting block plane. I checked out and finish-honed the L/N using the above techniques… that took all of 10 minutes….these are as close to perfect as you can get.View ImageMy 15-dollar #60 ½ has its stock carbon iron ($6.00), my #65 a thicker Hock carbon replacement iron ($35.00), and the L/N a thicker-still iron of A2 steel ($150.00 complete). The L/N is one heavy block plane….two or three ounces heavier than my large #65. It is more suitable for a leather holster than an apron pocket.View ImageI set the mouths up for combination work removing both end grain and long grain hardwood. One of the limitations of this model L/N is that the mouth is a bit tight for heavy cuts in boatbuilding softwoods, placing it at a disadvantage…so I’ll compare the planes using White Oak instead.View ImageThe stock, 70-year-old #60 ½ had no trouble at all making end grain cuts in White Oak.View ImageNeither did the pre-war #65 with Hock iron.View ImageNor did the L/N. I even tried my stock, standard-angle #18 on the far right on the oak end grain and it pared it adequately too….just not as effortlessly as the low-angle models.View ImageWill the stock #60 ½ take full-width shavings of tough oak edge grain? You bet. Easily and all morning long.Continued….“When we build, let us think that we build forever. Let it not be for present delight nor for present use alone. Let it be such work as our descendants will thank us for; and let us think...that a time is to come when those (heirlooms) will be held sacred because our hands have touched them, and that men will say, as they look upon the labor and wrought substance of them, ‘See! This our father did for us.’ “ --John Ruskin.
View ImageSo will the #65…View Image…and the L/N…View Image…but here’s where the stock #18 shines. As cheap as the old, standard-angle block planes go for, don’t be without a #18 or #9 ½ to match your low-angle #65 or #60 ½. In the middle of a project you’ll sharpen half as often.How long will the different makes of iron stay sharp? L/N's A2 steel with chromium and molybdenum added is tougher and will hold its edge longer. The only down side to A2 is that it doesn’t take quite the edge that good carbon does. Not by much though, and after a couple hours of work dulling both, I can barely tell the difference. But when freshly honed I can feel a difference, and if I were to go to A2 irons I’d try diamond paste on an indexing plate instead of stones. In the inevitable compromise between how sharp, ease of sharpening and edge retention, my ideal remains Hock carbon…but as you can see, I stumble along just fine with stock Stanley.View ImageAnd as a rabbet plane, this L/N hasn’t enough depth for anything deeper than a quarter inch, although it would work well as a shoulder plane for crossgrain work on small tenons. If you need a rabbet plane, buy a rabbet plane. An inexpensive, old Stanley #78, Record #078 or Miller Falls #80 can be made to work as well as the #60 ½ here. Let my friend Jake Darvall in Australia teach you how to fettle them:http://www.woodworkforums.ubeaut.com...hlight=stanleyThese techniques also work on newly-manufactured Stanley block planes, which also can be made to work well with an hour's fettling. Pre-war Stanleys may be filthy, rusty and out of true, but are generally less expensive because of it and much better made...and both flavors need the same work. When selecting tools for boatbuilding, keep in mind that teaching yourself to clean, flatten and sharpen can free up the money you need for all those other tools you need but don’t yet have.Additional detail on sharpening, bluing and fettling is found here:http://www.woodcentral.com/cgi-bin/articles.pl#smalserhttp://www.woodenboatvb.com/vbulleti...ad.php?t=48786http://www.woodcentral.com/cgi-bin/articles.pl
Great Post!!! Makes me think I should clean up a couple of my garage sale treasures.
Nice work BobSmalser,I personally leave the planes I buy in the condition how I got them but will flatten the sole and sharpen the blade , then I can use it for my work.
In the tool collectors club where I am a member from is the restoring to original or leave in the condition you find it in 50:50 .
I am probably leaysie and think when it works don't tinker with it.
Greetings Bernhard.
Good work, I too fixed up mine and made new blades 3/16" thick of O-2. the lever was broken on the 60 1/2 so I drilled it out and taped some threads and made a knob, with the 3/16" blades you have to make a longer screw too. The Brass one is a St James Bay casting.
Very interesting lever cap. I'm impressed.
I'm not as sophisticated. A machinist friend sent me a nice, thick 0-1 iron wiith the expectation I'd use it in a woodie. Well, I have enough woodies already and since it nicely fit a #4 or #5, I shortened a scrap #5 I had laying around to the length of a Junior Jack to use the iron.
I could have annealed and drilled it, but I couldn't bear to ruin such a perfectly flat back. The iron was made by Johnnie Kelso of Rex Mill. Does very nicely on figured Bigleaf music wood.
<!-- Play Voiceover --><!-- LEE CODE: NEW Voiceover code as of 9-21-05 by adrienne: --><!-- Send eCard --><!-- LEE CODE: NEW eCard code as of 9-21-05 by adrienne: -->
I've also made 50-degree, lead-weighted smoothers to see if they could compete with Norris and Spears:
With a flat sole, a solid mount, and a properly-sharpened quality iron, I think the only real difference between a Stanley and the prestige planes is the hype.
Edited 7/9/2007 8:13 pm by BobSmalser
Wonderful post!
It should be published as a text-book on recondtioning. FWW - are you listening?
Frosty
i don't know about your comments about the Sargent -- I have my grandfathers and i love the size and feel of it -- I use it all the time and it is my favorite plane.
I'm not poormouthing Sargent, per se. I'm poormouthing that particular plane, a 1960's Craftsman with gray paint.
I'm sure the older Sargents you probably have are much better just like prewar Stanleys are better than the stuff made in the 60's and 70's. Your lever caps are probably made of better and harder steel than mine.
The lever cap isn't a casting, but a soft, sheet metal arc that bends when the pressure is transmitted through the sole and iron in planing. Even with a dead-flat sole, it won't take full-width shavings in oak.
But the plane is too big for my hand.
Edited 7/10/2007 2:25 pm by BobSmalser
You are right -- the lever cap on mine is a fairly solid casting in bronze with a nickle plating. It cuts as smooth as silk.Dan Carroll
Here's parts of the finished article that goes to the publishers this week. Thanks, y'all's input is valuable:
quote
I first heard the word sweet used to describe a tool back in the family boat shop where I began working as a boy in the late 1950’s. Tools were supposed to be sweet, whatever that meant. It wasn’t until I graduated from the broom to the carborundum stones that I began to understand. A half century later I still hear the same discussions, only today most of it centered on the high price you have to pay to buy a sweet tool than what simple tasks you have to perform to make a tool sweet. Well, after you accidentally kick that expensive tool off the scaffold once or twice as we all eventually do, you may find that you can’t get by with one approach without the other for very long.
The humble block plane is one of the most important tools in boatbuilding, and one of the easiest planes to sweeten without spending money needlessly. After all, if you’ve selected this article to read, you probably have more than just a block plane you still need to buy.
I needed another small plane for the apron pocket, so for 60 dollars at auction I bought an antique tool dealer’s collection of rejects - some models poorly designed and made, and better models with a minor chip here and there, worn-out irons or missing parts. I made sure however, that none had major cracks that would interfere with function....
...Few are as bad as this Sargent, but when they are that bad, keep in mind that soles don’t have to be absolutely perfect like iron backs do. Just the toe, both ends of the mouth and heel need to be in the same plane to do fine work. In fact, Japanese planes are purposely set up with hollows in between those areas to reduce friction. Most of the chattering woodworkers complain about in these mass-produced planes isn’t because the iron is too thin, but because the sole isn’t flat – the critical area behind the mouth is in a hollow and is unsupported by the work piece - just like an entire third of my Sargent's mouth was in a hollow. With downward hand pressure, the front of the mouth holds down the wood fibers while the back of the mouth pins the blade against the cap iron to stabilize the cutting edge. If one or both ends of the mouth are unsupported, the result is like trying to cut a loose ribbon with tin snips. Indexing dye makes a major difference in how well you flatten, and flat is what makes the plane work well - or fail to....
unquote
