I have made a bunch of kitchen cabinet doors with a decent profile on door frame. I have discivered late in the game that the standard blum recessed hole when drilled breaks thru my door profiles. Yikes. I am out of luck for using concealed hinges? Does anyone make concealed hinge that monts further from door edge? Any ideas would be much appreciated.
There are some no mortice concealed hinges.
http://www.amazon.com/Surface-Mount-Totally-Concealed-Face-Frame-Hinge/dp/B001DSZL3O
Thanks, I will check them out.
As a cabinte maker I have run into this problem before so I feel your pain. The solution would be to find hinges that are made for thin doors, what this does is it allows you drill for a shallower cup, approx. 8-10mm. Because I am a business I use Hafele for all my hardware, the ones they sell are Duomatic- Thin Door Series. Blum might make something that's the equivalent. Hettich will also have this hinge as another option, these can be bought through a reseller, try a search online.
Good Luck,
o_
Thanks, I will research them.
