Does anybody have experience making a book press?
Janet
Janet
Janet, I've never built one but after a quick Google search of images, I don't think it would be terribly difficult to build one. You could adapt a bench screw or a couple of pipe clamps to do the heavy work. If you need a plan, I could probably do something for you.
It's the wooden screw that I am wondering about. How do you make a screw out of wood?
Janet
Do you have to have a wooden screw? There are tools for cutting threads in wood if that's what you want. Check out these links for examples.
http://www.fine-tools.com/gewind.htm
http://www.bealltool.com/products/threading/threader.php
There are others as well.
Most of the antique book presses use iron or steel screws threaded through cast-iron supports. You could make a wood support and these screws that are often used for veneer presses:
http://www.adjustableclamp.com/sp-6700.htm
Wooden screws aren't as strong, of course. Dowel threaders (dies and taps for wood) can also be found at Japan Woodworker:
http://www.japanwoodworker.com/product.asp?s=JapanWoodworker&pf_id=99.500.10&dept_id=12827
But, one should expect to exert a lot of force on wooden threads.
