I am bookmatching two quarter inch slices of curly maple. I have jointed the edges to be glued, but I cant seem to get a clean glue line. Is there a better way to prepare the egdes of thin stock with difficult grain?
Did you joint them separately, or together? what technique did you use?
first i ran them one at a time, then I ran them together. running them together worked better and the glue joint was semi-decent but I plan on making a couple more of these tables and I have to do better.
Thanks for the response!
We are working with thin walnut veneer right now and get perfect gluelines by placing the veneer between 2 pieces of 3/4"mdf and then rout the edge with a flush trim bit...you could rout them both at the same time along a deadnuts mdf staightedge...helps if top and bottom boards are flush...
hope this helps,
silver
Thank you I'll try it!
Clamp both pieces down flat on a piece of scrap. They should be oriented the way they will be glued up and spaced about 3/8" apart. With a sharp 1/2" bit in your router and a straightedge, rout both pieces at the same time. Of course, the sharper the bit and the less material you take off, the better the joint will be. I use this procedure for a wide range of materials - plywood, laminates, solid surface - you name it. I don't know that there is a technical term for this procedure, but I have often heard it referred to as "marrying" a seam. Hope it works for you.
Hairball, thanks I'll try that!
Hack,
To help visualize the jointed edges, I place both pieces on a light box or window with good exposure to sunlight; with the jointed edges butted together, the slightest gaps can be observed.
To fix these gaps, I use a freshly-honed handplane and a shooting board.
Good luck,
-Jazzdogg-
Jazzdogg, Thats great advise. thank you
