Boring Saw Blade Thread (please read)
Ok…
Is this possible or am I dreaming?
Tomorrow the brown truck will be bringing me a makita 18v Li-Ion cordless combo pack with the 6-1/2 circular saw (BSS610).
Will I be able to use that circular saw to cut sheet goods (hardwood plywood, melamine) to size with near zero tear out like I can with my sidewinder and carbide plywood blade (the brand escapes me).
Also, so that I only have to buy once: Who makes the best 6-1/2″ blade for this kind of cutting (and what model is it)?
Thanks in advance,
Eric.
I have that setup too. I would assume that with a good blade you'd get good cuts but I don't think it will be perfect. I use mine for rough cuts or framing lumber. It's a really nice cordless saw, but it's just that-a cordless saw. I wouldn't expect to break down sheet stock for a kitchen's worth of cabinets with it.
What are you using now for these ultra-clean cuts you get in sheet goods?
I'm using the stock blade but I would think any 6 1/2" blade from a decent blade mfr. would be pretty good. I haven't even looked into it so I'm not sure who to recommend. I would check the really good blade folks-I know Ridge Carbide makes a staggering number of blades, and they may have something.
Maybe someday I'll know a little something.
Hi JJV-
I suspect the 5800rpm of a 7-1/4 sidewinder is what makes a difference compared to the 3700 rpm of the 6-1/2 cordless.
As for what I'm using now for my 'ultra clean cuts' in sheet goods... well, once the full sheet is broken down, the forrest hi-at on my TS does a great job...
Right now for cutting the full sheets, I have some plywood carbide blade from a big box store (Oldham maybe?, < $10 anyhow) on my corded sidewinder. With a shop-made guide it does a passable job on plywood and a very nearly passable job on melamine. I'd just like to get that passable/nearly passable results from the cordless. Dunno if that's wishful thinking or not.
I suspect my workflow probably won't change much when top quality is the utmost concern - cut the full sheet apart to 1" oversize pieces, then trim to exact size on the TS. I have no desire to muscle a full sheet thru the TS.
E.
Gotcha. I thought you were saying you got finish cuts with your circ saw-my bad.
Well, I think it will be fine for the occasional trim cut, esp. if you're finishing on the TS with a Forrest.
Of course, if you want to go there, you can always get an EZ Guide or a Festool saw... :-)
Edited 2/16/2007 9:26 am ET by JJV
festool...
...from what I have read that sounds like something that could be quite addictive. Its best that I stay away from things like that... I already have several other shop related addictions, the demons of which I battle on a far too regular basis.
thanks for the advice just the same...maybe I'll go check them out...
E.
Not knowing where you live. I would let that new battery warm up to room temperature before charging it. (24 hours)
Bruce S.
