Bosch and Festool Sander Dust Collection
Between the the Bosch 1250DEVS and the Festool RO 150E sanders, is dust collection equal? I saw a review in a older Fine Woodworking ( I think) magazine and the Bosch took top place with the Festool second ( I’m not 100% on this, but think I’m close). I know Festool has discontinued the RO 150 and a new sander is expected to takes its place soon, but I’m hoping to find a refurbished one if it has the better dust collection or just wait for the new replacement.
I can't compare since I don't have the Bosch, but I have 2 Festool RO150's. The dust collection on them is as good as anyone could reasonably ask for. For what it's worth...
DR
I reread the review in the latest FWW last night and couldn't find why the tool with the best commentary didn't rate best overall. I can only assume that it was twice the price. For what its worth - I bought the festool so that I could minimise clean up and drop sheets on extended projects inside (amateaur working over several weekends to finish a task trying to minimise the disruption in the house).
So far I have had no complaint.
Dave
I own the festool and have used the bosch. The festool is better than the bosch IMO.
Craig,
Your answer is a little open. Could you please explain why you feel that the Festool is better?
I need to get a variable speed sander, and would buy the Festool. For the cost, it would have to be much better than the Bosch.
I've used both and prefer the Festool for two reasons; the paper last longer and it get more of the dust. The Bosch does a good job, better than a lot of others, but I just think the Festool does it a bit better. AND, the paper last longer on the Festool, I don't have the slightest idea why, I'm told it is because of the air circulation, but I don't know for sure.
Makes sense. Thank you.
I have the 1250 and I think the dust collection rocks. Its hooked to a fein mini and when sanding flat stock, there is no dust left on the work. Now if you sand an edge, the dust will fall, but I imagine that would be the same with the festool.
I have only played with the festool ro150 at woodcraft and its very similar to the 1250. Both are very heavy duty tools. The Bosch will take off quite a bit of material when set on the wide orbit mode. Both sanders will take you for a dance in that mode with coarse paper on the fastest speed. The Bosch is a 2 handed sander, I keep one and on the rounded grip on top and usually the other on the vac hose which works out nicely. Considering that the Bosch will come in at about 150 bucks cheaper then the rotax, that was enough for me to go with it. I haven't been disappointed.
