Just given this as a first router. Is this mainly for *light* work , pine, etc, or can it hold its own in oak? Thanks.
I own that same router and have been happy with it. I use it for all kinds of edge treatments on various hardwoods.
And using a 1/4 inch upcut spiral bit I've even cut 3/4 inch deep mortises in oak. I did this in 3 passes to minimize strain on the tool and the bit.
It's a very capable little router.
Thanks, exactly what I wanted to know....can it be used in a router table?
No reason not to, with the same approach MIO mentions.
Ty.
I have a few with multiple bases. It is a worthwhile tool that really becomes usable in the plunge base. Just remember it’s a 1HP, 1/4 collet tool and you’ll be fine. Height adjustment on the fixed base was a wonder when it came out. Since then it has been out done by the competition.
The plunge base takes care of this but, I would think it would be clumsy for table use. Too late now but, I did take advantage of clearance sales on them when the 1-1/4 HP version came out. I picked up two for what my first one cost quite a few years ago.
This is the older model right. Newer one is 1.25 hp I think? I have three of the 1 hp I keep loaded with certain bits I use often. Two things that would make me hesitate about using it in a table. The clamping mechanism that holds the router motor to a certain height is finicky and sometimes slips under pressure. Second is that changing the bits is a PITA. You have to hold in a stop to keep the collet from spinning loose, sometimes you need three hands to do it. Just my experience.
But the wood doesn't matter - cuts fine. Its the size and profile of the bit that are significant. If you edge trimming or using straight bits its fine.
Thanks🤙
