I bought the best, but it doesn’t seem to run straight along a fence. After about 5 inches it runs left away from the fence. I try not to force it and I’m using Progressor wood blade on pine and mdf. Any suggestions? Thanks, Todd
make sure the blade is seated tight .....
Can you do without the fence? Sounds like you're simply getting drift, like on a bandsaw.
You did buy the best, I have used this type jig saw for 8 plus years and never had a problem, make sure when you tighten the blade that it is facing true forward and not angled, or perhaps try a fine blade, I like the T111 (I think thats the type) blade, it seems to work good. If you still have trouble, contact Bosch and see if perhaps it needs service.
I have had the same problem on the Bosch jigsaw. Frequently, the blade does not sit properly in the roller guide, regardless of blade type. This occurs when using a saw guide or straightedge. It appears the tooless (clic?)blade change engineering did not allow for a tight enough seat in the roller guide for the blade. I have read the newer models have improved blade "seating'. I purchased my Bosch in late 2001. Not sure there is much we can do now though, except use a circular saw.
I have heard of others having this problem, but then some don't. And I've heard other brands don't. I can see why a jigsaw might tend to drift, but if it's a design flaw in this brand, or a defect in my saw, then maybe I should look elsewhere. Or maybe the advantages of this brand outweigh this characteristic. Is there any consensus on this? Todd
Sore,
Don't expect a jigsaw to follow a fence. YOu are going to get drift just like on a bandsaw . Can't think of any situation(off the top of my head) in which you should need to make a cut requiring a fence. If you need to cut that straight cut it with a circular saw.
Mark
The Prof said: Don't expect a jigsaw to follow a fence. YOu are going to get drift just like on a bandsaw.
I agree; in fact, I'd assume drift is even more likely with the jigsaw since the blade is unsupported on one end. The Bosch is the best jigsaw around, but some woods (or grain angles) will cause drift worse than others. The circ saw with a good blade is the best bet for a truly straight edge if the workpiece won't fit on the tablesaw.View Image
". . .and only the stump or fishy part of him remained."
Green Gables: A Contemplative Companion to Fujino Township
I've had a Bosch for lots of years. Early on I tried running it against a fence and found that it just doesn't work. You get drift one way or another. I guess that's just not a function of a jigsaw, and you need to use a circular saw against the fence, which I do all the time with perfect results. Other than that, my Bosch has been a fantastic tool.
