If I buy a PR110 subbase, will that allow me to use the template guides that I currently use on my Porter Cable 6902 router?
If you are talking about the screw-in bushings, most manufacturers have made PC bushings the defacto industry standard.
I have that Bosch router, and I needed an adaptor to use my PC bushings. but I dont know about that specific base.
I called Bosch and was told the PR110 is the subbase to buy to allow me to use the PC guide templates. I guess I will give it a try.
I recommend you look at the RA1100 bushing adapter instead it is much easier to install and won't need to be centered (assuming your primary base is centered) like a subbase would.
Thanks will look into that.
